Author Topic: 1.6Block to a 1.9Head question plus a few more.  (Read 6365 times)
Reply #15October 18, 2012, 02:28:22 pm
carrizog60
  • 978
Re: 1.6Block to a 1.9Head question plus a few more.
« Reply #15 on: October 18, 2012, 02:28:22 pm »
i have a g60 flywheel on my 1.9td and idle sounds normal so that would work ok.
i did it because i have a tdi gearbox
Portugal
Reply #16October 18, 2012, 03:03:00 pm
Hoble
  • 76
« Reply #16 on: October 18, 2012, 03:03:00 pm »
VR trans has the wrong bell housing for a TDI...
I know. i have 4 different 4 cylinder trannys kicking around, all you do is swap the bell housings and your golden
Reply #17October 18, 2012, 07:20:15 pm
« Reply #17 on: October 18, 2012, 07:20:15 pm »
you cant swap the bell housing, as it is part of the trans case...
you can take the VR guts and dump them in a 4 banger trans case tho...
Reply #18October 19, 2012, 08:38:36 am
Hoble
  • 76
« Reply #18 on: October 19, 2012, 08:38:36 am »
Actually you can swap them. It's rather simple. And if its all one piece then how would you take out the diff? Take a look at your trans and you'll see the seam and bolts holding it together.
Reply #19October 21, 2012, 08:32:15 am
AndyBees
  • 21
« Reply #19 on: October 21, 2012, 08:32:15 am »
The Bellhousing is part of the tranny ........... unbolt, guts fall out!
VW Diesels 45 years, TDIs 23 years
2000 Jetta TDI, 401k miles, given to my son
1984 Vanagon (ALH TDI, 11k mile 33 day road trip to Alaska pulling a popup camper, 26 mpg, 2016 31 days to Alaska and return) Typical MPGs 32-36
Reply #20October 22, 2012, 08:49:39 am
« Reply #20 on: October 22, 2012, 08:49:39 am »
i believe you can swap the "bellhousing" from vr6 to the 4 cylinder style, but its not simple like many other cars because like others have said the bellhousing is also half the case.
Reply #21October 22, 2012, 10:47:40 am
« Reply #21 on: October 22, 2012, 10:47:40 am »
thats what i been saying...
its not just "swap the bellhousing"
its "swap half the trans case"
Reply #22October 22, 2012, 11:06:15 am
« Reply #22 on: October 22, 2012, 11:06:15 am »
Ok it read like you meant you have to swap both sides of the trans which I didn't think was true
Reply #23October 23, 2012, 06:23:26 pm
Hoble
  • 76
« Reply #23 on: October 23, 2012, 06:23:26 pm »
Yes you are correct but you make it sound a lot harder than it actually is. I know people who have done 6 speed vr to a 1.8t. its not that hard if you have any mechanical experience. Pay attention to what you are doing and be care and your fine.
Reply #24October 24, 2012, 12:46:51 pm
« Reply #24 on: October 24, 2012, 12:46:51 pm »
nope, half case swap..
gotta pull all the old races and shizz out of the old case half, and install it in the new one..
