Author Topic: Ye 'Ol cold start thread  (Read 29688 times)
Reply #30January 07, 2012, 09:03:27 pm
Re: Ye 'Ol cold start thread
« Reply #30 on: January 07, 2012, 09:03:27 pm »
How many volts do you have going to each glowplug? That's a fairly long run of wire you have. I doubt it's your problem but it could be worth looking at.
Reply #31January 08, 2012, 07:34:08 am
veector
  • 95
« Reply #31 on: January 08, 2012, 07:34:08 am »
Ahh good old cold starts, after getting my advance cable hooked up she fires right up but sounds ROUGH for a few seconds.  I dont even have a block heater, how hard is it to install one?
1981 Jetta D
1997 Jetta TD
Reply #32January 08, 2012, 09:12:47 am
« Reply #32 on: January 08, 2012, 09:12:47 am »
I've been trying to figure out a better battery tie down since I got the car in 2007. Hey, it works.
Back on track here, I had another hell of a time starting her today.. I tried half cold start lever, which should be effectively half of the full movement, ie. 0.05mm bumping my idle static timing to 0.95mm. It didn't help.
The engine turned and turned billowing dark smoke from the pipe, and when it caught off it ran rough for atleast 10 minutes.
Reply #33January 08, 2012, 09:29:32 am
« Reply #33 on: January 08, 2012, 09:29:32 am »
Pulling the cold start out may not be exactly the same as bumping the timing to 0.95. It depends on your pump and when your pump starts increasing the dynamic timing. Most likely it is the same though.
Reply #34January 08, 2012, 09:33:11 am
« Reply #34 on: January 08, 2012, 09:33:11 am »
knock a soft plug out of the back of the block, and then pop a block heater in there..
Reply #35January 08, 2012, 10:37:50 am
dieselweasel
  • 312
« Reply #35 on: January 08, 2012, 10:37:50 am »
-have you checked compression?
-I assume this is a mech head...are the valves in proper adjustment?
Reply #36January 08, 2012, 11:19:42 am
  • 4549
« Reply #36 on: January 08, 2012, 11:19:42 am »
X2 on the cold lever pull out,  not the same as changing the timing.  My lever hardly does anything until it gets 3/4 of the way out.  I guess I have slack in the system.  But I don't need the cold lever to start my car.  Fires off after glow and does rattle around a bit but I just solved that by adding a stiff cable to the accel lever.  Doubles as my cruise control.  When cold I just nudge it a bit for the first block or so to up the idle until it makes the magic sound of smooth sailing.
When I pulled my injectors out yesterday to do the compression check I have been unable to do till now I noticed that the "rebuilt" injectors I put in just 6 months ago were a bit black on the heat shield.  And I run ATF in the fuel.  So, maybe you might need to concentrate on that part to see what you can see.
Reply #37January 08, 2012, 06:54:56 pm
« Reply #37 on: January 08, 2012, 06:54:56 pm »
The dial indicator seemed to start tracking advance as soon as the handle started to move, so i believe half handle to be half of the 0.10mm advancement of the CS handle.
It is a 91 hydraulic engine, the pump is a TD body with a 91 n/a lid on it. I think it may have gotten worse now that I have jumped down to 0.90mm and i backed out the fuel screw a bit to bring the idle down a tad. So I think I'll try jumping up to 0.95mm and raising the idle by the idle adjustment, and maybe backing off some of the fuel screw to not hang on idle.
I have not checked compression yet, I have not been able to find a supply for heat shields at a reasonable price around here.
Reply #38January 08, 2012, 06:57:30 pm
« Reply #38 on: January 08, 2012, 06:57:30 pm »
Yea, about that bungee cord....  Thats how I got my Jetta, the too big battery bounced while going around a corner and smacked the rad fan, fried the engine.  Instant $100 car.  Thats how I gots my diesel!  Lemme know when that happens to yours, I'll beat the scrapyard on price!
:D I wouldn't let that stop me, just be more of a reason to get the damn TDI in there and stop dealing with all this B.S...
Reply #39January 08, 2012, 08:53:47 pm
AudiVWguy
« Reply #39 on: January 08, 2012, 08:53:47 pm »
Another thing you could try is to go to the hardware store and buy clear vinyl tubing to replace the fuel in and out lines to look for air in the lines. This stuff doesn't last long, it gets hard, motorcycle fuel line is best. Do you have a way to keep the GP's on longer than just the relay?
I'm dealing with a similar problem. Starts right up, but runs on 3 cyl for 45 sec then finally clears to 4 cyl. Cracking the inj lines gave up #2 as the slacker, but cleaning and repop testing didn't change anything. New return lines off the injectors, nada. I have a lift pump wired to stay on as long as the GP's are on, thinking maybe there was a slight seal leak, didn't make any difference. After the first crappy start of the day it's great unless it sits another 10 hours.
Reply #40January 08, 2012, 09:16:27 pm
« Reply #40 on: January 08, 2012, 09:16:27 pm »
weird, were having the same issue.
I have clear fuel lines through the engine bay, no bubbles.
I also have the glow plugs fully manual, they can stay on for as long as I want. Sometimes when cold i glow for 25 seconds. I also have an electric lift pump that is on the whole time the key is on, I run it while i glow the plugs.
Reply #41January 09, 2012, 08:19:01 pm
AudiVWguy
« Reply #41 on: January 09, 2012, 08:19:01 pm »
And.... if you plug it for an hour, you'd never know there was any friggin problem.
Reply #42January 09, 2012, 08:24:51 pm
« Reply #42 on: January 09, 2012, 08:24:51 pm »
Plugging mine in only helps a bit.. I am friggan stumped..
Reply #43January 10, 2012, 03:05:05 am
Mark(The Miser)UK
  • 1557
« Reply #43 on: January 10, 2012, 03:05:05 am »
You've discounted injector issues, so it could be compression ratio, or maybe a lazy cam follower.
Don't worry about heatshields, just reuse them. Reforming, as  per my description [somewhere] is better. I had one heatshield fail [out of the car] in reforming a set of 4, 15 times :o
Therefore reforming once is completely safe.
Mark-The-Miser-UK
Reply #44January 10, 2012, 05:02:53 am
veector
  • 95
« Reply #44 on: January 10, 2012, 05:02:53 am »
Correction, how easy is it while everything is in the car?  I just can imagine how to knock it out, arent they pressed in?
1981 Jetta D
1997 Jetta TD
