Thanks for the response.
What do those of you who have EGT gauges consider an unsafe temp for this engine. (AAZ with K03 turbo) and when you reach this temp do you pull over and shut her down?
Generally speaking a true turbo engine (with the oil squirters, TD pistons, etc) can withstand temps up to 1400°F. Most people like to keep temps below 1300°F.
Exhaust Gas Temperature behaves totally differently from cooling system temperature. The effect of a change in fueling causes an almost instant change in EGTs - what you are measuring is how hot the last 'burn' was in the engine as opposed to how hot the engine cooling system has gotten. You can change the 'burn' temperature by adding or reducing fuel with your right foot
Once you have your EGT gauge, you can dial in the fueling on your pump up so that you won't go over 1300°F or so even when holding the pedal to the floor going up a steep grade. That way you can basically run your engine as hard as you want all day long and know you aren't ever in the danger zone. Or you can leave yourself with a bit more fueling headroom for when you need it, but watch the gauge when climbing to ensure you stay in the safe zone.
By far the biggest danger is sustained climbing. Hard acceleration doesn't usually last more than a few seconds, whereas driving up the side of a mountain can last several minutes. Plenty of time for things to get nice and melty.
