Author Topic: Crankcase Evacuation?  (Read 2002 times)
July 07, 2011, 08:13:05 am
Vanagoner
  • 219
« on: July 07, 2011, 08:13:05 am »
I searched, but could not find anything on this.
Has anybody tried a crankcase evacuation system on their IDI?
http://www.moroso.com/catalog/categorydisplay.asp?catcode=13023
It is supposed to pull a slight vacuum in the crankcase, aiding with ring sealing, reducing pumping losses, and helping eliminate oil leaks.  It also would eliminate the possibility of a vent line runaway.
Anyone?
Sage
Reply #1July 07, 2011, 09:07:37 am
81 vw pu
Re: Crankcase Evacuation?
« Reply #1 on: July 07, 2011, 09:07:37 am »
I have this kit on my gasser drag car and it works well, but seems to burn out the check valves often.
The oil separator and check valves are factory Chrysler parts you can buy at any auto parts store.
I would say if the oil separator did its job and could handle the volume of blow by it would work, but if any of
that oily mist hits the hot exhaust you're gonna leave a smoke trail.
