Author Topic: building my motor some questions  (Read 4921 times)
Reply #15May 31, 2011, 09:21:34 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: building my motor some questions
« Reply #15 on: May 31, 2011, 09:21:34 pm »
Lots of good advice in here. although, I must say that I think you are assuming a lot here. Your build is not a clutch killing monster by any means. Unfortunately... :(
i would recommend a stock 210mm clutch kit and flywheel as was mentioned before. Also, TDC is TDC. No mistaking that one.
I realize that, however, the clutch that I have from my car before the rebuild was slipping already when I would put it under heavy load with the stock engine, I dont expect better with more horsepower.
Ted
Did you have a worn 200mm clutch in there before? If so, the new 210mm will work just fine.
Reply #16June 01, 2011, 07:13:26 am
« Reply #16 on: June 01, 2011, 07:13:26 am »
210mm clutch is leaps and bounds better than a 200mm clutch. theres quite a bit more holding power with the 210mm
Reply #17June 03, 2011, 07:39:00 pm
mean88
  • 38
« Reply #17 on: June 03, 2011, 07:39:00 pm »
I just checked my old clutch it is a 200 mm stocker.  It has well over 250,000miles on it so......
Reply #18June 04, 2011, 09:48:58 am
« Reply #18 on: June 04, 2011, 09:48:58 am »
how can you tell its stock? ive NEVER seen a clutch go that far before..
