Author Topic: building my motor some questions  (Read 5043 times)
May 28, 2011, 06:40:26 pm
mean88
  • 38
« on: May 28, 2011, 06:40:26 pm »
I have a 1.6 turbo diesel, shaved block, .5mm over, all new bearings and seals. I bolted a new 1.9 head on it, a tdi intake, and a t3 turbo.  Block has the new arp head studs and a metal 1.9 gasket.
I need a new valve cover for it as the 1.9 head seals differently and i have had no luck what so ever in locating one online most are tdi not idi, suggestions?
I also need a clutch as I feel the stock one wont hold, as I blocked my waste gate completely and my pump is turned up. I am having trouble finding the correct clutch for my application.  I use the car as a daily driver for work, but I know this monster will chew the stock clutch. Most clutches I found online dont appear the same as the stock one.
Any ideas on either?
Thanks
Ted
Reply #1May 28, 2011, 09:07:57 pm
mystery3
  • 774
Re: building my motor some questions
« Reply #1 on: May 28, 2011, 09:07:57 pm »
What size is your clutch?
Reply #2May 29, 2011, 06:25:22 am
mean88
  • 38
« Reply #2 on: May 29, 2011, 06:25:22 am »
It's.a stock clutch 200mm I believe.
Reply #3May 29, 2011, 08:52:35 am
Powered by Spearco
  • 1203
« Reply #3 on: May 29, 2011, 08:52:35 am »
For the VC gasket, try and locate one here in the (wanted/for sale) section or in the (vendor) section.
I bought mine from my local parts house. Also, if no luck, theres always the dealer.
The clutch... 200mm will do but so would the 210mm along with the 16V PP. if you want to have any spare life for further moding.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #4May 29, 2011, 05:28:19 pm
mean88
  • 38
« Reply #4 on: May 29, 2011, 05:28:19 pm »
is there a clutch kit somewhere online that I can get a built setup?  I understand that if i go to a 210 clutch I have to re-mark TDC.  My other question is this, what engine is the pressure plate and disc from that I need for a 210 16V?(most sites show clutches with engine liters and what car they are from)  I have an AOP trans my car is a 90'.  Are most using a stock 16v clutch or what?
Thanks
Ted
Reply #5May 29, 2011, 05:38:18 pm
Powered by Spearco
  • 1203
« Reply #5 on: May 29, 2011, 05:38:18 pm »
There is lots of places that give you a custom setup for clutches. Stock VW clutches are fine for you build.
I used a stock 210mm FW with an 8V gasser GTI disk with a 16V PP for better clamping force. Also, I used a VW Beattle 200mm disc that was a solid type. No problems or chatter.
As far as TDC point on the FW. The "0" is 0. If and when you do your clutch. Moc up the PP and FW to TDC on the engine and check then.
'13 Golf R:. Tuned
'98 Puch G320
Reply #6May 29, 2011, 08:25:12 pm
mean88
  • 38
Reply #7May 29, 2011, 08:28:41 pm
Powered by Spearco
  • 1203
« Reply #7 on: May 29, 2011, 08:28:41 pm »
Perfect. Get it.
'13 Golf R:. Tuned
'98 Puch G320
Reply #8May 29, 2011, 10:12:59 pm
ffgb
  • 244
« Reply #8 on: May 29, 2011, 10:12:59 pm »
That's what I have along with a lightened flywheel and I absolutely love it!  Just make sure to also get that brass bushing, the one that guides the rod from the throwout bearing to the pressure plate!
Reply #9May 29, 2011, 11:02:24 pm
mystery3
  • 774
« Reply #9 on: May 29, 2011, 11:02:24 pm »
Spec makes a bunch of clutch kits for vw's if you want something overkill which is how I usually prefer to do things.
http://www.specclutchsuperstore.com/lexus-aero-c-485_662.html
You may need to call them to order and make sure you're ordering the right parts.
Reply #10May 30, 2011, 12:20:22 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #10 on: May 30, 2011, 12:20:22 am »
Lots of good advice in here. although, I must say that I think you are assuming a lot here. Your build is not a clutch killing monster by any means. Unfortunately... :(
i would recommend a stock 210mm clutch kit and flywheel as was mentioned before. Also, TDC is TDC. No mistaking that one.
Reply #11May 30, 2011, 05:54:03 pm
mean88
  • 38
« Reply #11 on: May 30, 2011, 05:54:03 pm »
I realize that, however, the clutch that I have from my car before the rebuild was slipping already when I would put it under heavy load with the stock engine, I dont expect better with more horsepower.
Ted
Reply #12May 30, 2011, 06:31:19 pm
rallydiesel
  • 1880
« Reply #12 on: May 30, 2011, 06:31:19 pm »
If missing the whole valve cover then I believe the casting is the same between the 1.6 and 1.9 so you could drill holes and use the 1.6 cover, which is more common.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #13May 30, 2011, 09:00:17 pm
« Reply #13 on: May 30, 2011, 09:00:17 pm »
does it have 3 studs on the cam caps??? 1.9 should.. so aaz is what you seek..
Reply #14May 31, 2011, 09:20:13 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #14 on: May 31, 2011, 09:20:13 pm »
This is what I did. No problem. Used a Euro 2.0l valve cover so it was aluminium and used a rubber gasket.
