Author Topic: Quick valve seal question  (Read 3934 times)
November 16, 2010, 06:45:56 pm
somepunk22
  • 79
« on: November 16, 2010, 06:45:56 pm »
I pulled this rebuilt head apart to port it. After I removed the valves, I noticed some damage to the seals.
Reply #1November 16, 2010, 07:19:58 pm
Re: Quick valve seal question
« Reply #1 on: November 16, 2010, 07:19:58 pm »
My firm opinion is that you need new seals.
IIRC you're supposed to put the valves in and then install the seals, that lets you wriggle the seal around and hopefully not rip it apart. Also light grease/oil them for installation.
Reply #2November 16, 2010, 07:36:14 pm
somepunk22
  • 79
« Reply #2 on: November 16, 2010, 07:36:14 pm »
K. Glad I kept the set I got a few years ago with the Victor Reinz head gasket set.
Reply #3November 16, 2010, 07:41:28 pm
somepunk22
  • 79
« Reply #3 on: November 16, 2010, 07:41:28 pm »
Also I seem to be having trouble finding a MLS headgasket. I emailed Myke W with no response. Anyone know a good supplier? Thanks.
Reply #4November 16, 2010, 07:46:45 pm
« Reply #4 on: November 16, 2010, 07:46:45 pm »
Yeah I'm not sure if Myke is still selling stuff, he was active on here just a couple weeks ago. I've since PM'd and emailed him with no response :-\.
Reply #5November 16, 2010, 07:51:15 pm
« Reply #5 on: November 16, 2010, 07:51:15 pm »
Reply #6November 16, 2010, 08:00:59 pm
« Reply #6 on: November 16, 2010, 08:00:59 pm »
Ah... but did you keep the little plastic cap from your Victor Reinz kit that goes on the end of the valve stem to protect the seal as you're pushing it over the valve?!    ;) ;D
Reply #7November 16, 2010, 11:12:46 pm
Wayland
  • 364
« Reply #7 on: November 16, 2010, 11:12:46 pm »
I cut the corner out of a heavy plastic bag and used that to install the valves through the seals. Worked great.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #8November 17, 2010, 06:01:17 am
somepunk22
  • 79
« Reply #8 on: November 17, 2010, 06:01:17 am »
Just checked this morning. Luckily was still in the box.  8)
Reply #9November 17, 2010, 06:11:18 am
Mark(The Miser)UK
  • 1557
« Reply #9 on: November 17, 2010, 06:11:18 am »
Push a lightly lubed valve through and see if the seals grip.
Clearly these have not been exposed to high temperature oil yet so they should be fine IMO
Mark-The-Miser-UK
Reply #10November 17, 2010, 01:47:13 pm
somepunk22
  • 79
« Reply #10 on: November 17, 2010, 01:47:13 pm »
http://www.thedubdoctor.com/parts_site/
Did they only do 2 or 3 notch gaskets for the 1.9? I need a single notch.
Also this is Myke W, correct? He doesn't seem to be responding these days...
« Last Edit: November 17, 2010, 01:49:32 pm by somepunk22 »
Reply #11November 17, 2010, 01:48:08 pm
somepunk22
  • 79
« Reply #11 on: November 17, 2010, 01:48:08 pm »
So reinstall valves with little plastic cap, and I should be ok? Anyone else agree? Thanks.
Reply #12November 17, 2010, 03:07:45 pm
« Reply #12 on: November 17, 2010, 03:07:45 pm »
Did you call him?
If you left a message he will call you back.
Reply #13November 17, 2010, 03:12:31 pm
quasi
  • 26
« Reply #13 on: November 17, 2010, 03:12:31 pm »
Last contact I had with Mike_W was about 2 weeks ago, when I ordered some stuff an receved it fairly quick.
1981 VW Caddy
1984 Saab turbo
1974 1/2 MGB-GT
Reply #14November 17, 2010, 04:08:06 pm
« Reply #14 on: November 17, 2010, 04:08:06 pm »
You've already got 'em, the head's out... I'd personally say go for it and rest easy.
The sequence is:
1) install valve
2) install protective cap
3) press on valve seal
4) remove cap
Lather, rinse, repeat.  ;-)
« Last Edit: November 17, 2010, 06:58:54 pm by Vincent Waldon »
