Author Topic: Leaking Coolant on the passengerside of the engine  (Read 2131 times)
November 11, 2010, 03:24:39 pm
jaysen71581
  • 211
    Hagerstown, MD
« on: November 11, 2010, 03:24:39 pm »
Just as the title says, i am leaking coolant on the passenger side of my rabbit, it has 1.6td motor in it, the connections into and out from the waterpump are good, anyone come across this?
Reply #1November 11, 2010, 03:56:33 pm
rallydiesel
  • 1880
Re: Leaking Coolant on the passengerside of the engine
« Reply #1 on: November 11, 2010, 03:56:33 pm »
Probably weeping from the waterpump gasket or shaft o-ring.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2November 11, 2010, 04:10:24 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #2 on: November 11, 2010, 04:10:24 pm »
Its a new autozone waterpump.hmmmm def should of went to Napa ... Should i just take it off and reseal it if i determine it is the gasket
Reply #3November 11, 2010, 04:26:15 pm
« Reply #3 on: November 11, 2010, 04:26:15 pm »
could be the oring if you did that kind of replacement...pic of leak please :D
Reply #4November 11, 2010, 04:49:17 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #4 on: November 11, 2010, 04:49:17 pm »
I shall on sunday when ill have time to mess with it. Thanks and ill keep you updated !!
Reply #5November 11, 2010, 11:13:54 pm
Quantum TD
  • 1195
« Reply #5 on: November 11, 2010, 11:13:54 pm »
Get the titanium waterpump offered by Faberge'. Get it powdercoated and extruda-hone the interior passages. You'll never replace it again.
Cost: Priceless.
« Last Edit: November 14, 2010, 12:28:59 pm by Quantum TD »
Reply #6November 19, 2010, 10:25:00 am
jaysen71581
  • 211
    Hagerstown, MD
« Reply #6 on: November 19, 2010, 10:25:00 am »
Believe it or not it was a clamp that was cockeyed lol i was able to fix that and replace the hose that goes from my over flow to the piping, im working on burping the air out of the system...
