Leaking Coolant on the passengerside of the engine
Topic: Leaking Coolant on the passengerside of the engine (Read 2204 times)
November 11, 2010, 03:24:39 pm
jaysen71581
Hagerstown, MD
November 11, 2010, 03:24:39 pm »
Just as the title says, i am leaking coolant on the passenger side of my rabbit, it has 1.6td motor in it, the connections into and out from the waterpump are good, anyone come across this?
November 11, 2010, 03:56:33 pm
rallydiesel
Re: Leaking Coolant on the passengerside of the engine
November 11, 2010, 03:56:33 pm »
Probably weeping from the waterpump gasket or shaft o-ring.
1991 Jetta TD - sold
2001 Golf TDI - Son's
November 11, 2010, 04:10:24 pm
jaysen71581
Hagerstown, MD
November 11, 2010, 04:10:24 pm »
Its a new autozone waterpump.hmmmm def should of went to Napa ... Should i just take it off and reseal it if i determine it is the gasket
November 11, 2010, 04:26:15 pm
November 11, 2010, 04:26:15 pm »
could be the oring if you did that kind of replacement...pic of leak please
Round 2
November 11, 2010, 04:49:17 pm
jaysen71581
Hagerstown, MD
November 11, 2010, 04:49:17 pm »
I shall on sunday when ill have time to mess with it. Thanks and ill keep you updated !!
November 11, 2010, 11:13:54 pm
Quantum TD
November 11, 2010, 11:13:54 pm »
Get the titanium waterpump offered by Faberge'. Get it powdercoated and extruda-hone the interior passages. You'll never replace it again.
Cost: Priceless.
Last Edit: November 14, 2010, 12:28:59 pm by Quantum TD
November 19, 2010, 10:25:00 am
jaysen71581
Hagerstown, MD
November 19, 2010, 10:25:00 am »
Believe it or not it was a clamp that was cockeyed lol i was able to fix that and replace the hose that goes from my over flow to the piping, im working on burping the air out of the system...
