Author Topic: pics of fmic install on mk1 rabbit? anyone?  (Read 15985 times)
Reply #15August 23, 2010, 05:09:31 pm
erice1984
  • 263
Re: pics of fmic install on mk1 rabbit? anyone?
« Reply #15 on: August 23, 2010, 05:09:31 pm »
What is PD150?
1980 Rabbit 1.9TD
Reply #16August 23, 2010, 05:13:22 pm
GEE-BEE
  • 1604
« Reply #16 on: August 23, 2010, 05:13:22 pm »
Intake manifold, see jacks car in this post, faces toward the driver's side, better performance, need to a race pipe egr delete ( streettoys 2000 ) vendor here...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #17August 23, 2010, 05:43:12 pm
jack's lack
  • 275
« Reply #17 on: August 23, 2010, 05:43:12 pm »
GB
Forget my intake. I want bugnut's custom job :o
OP if the battery is already relocated then I would def run one with the the cool air running up the port side. Assuming you can find an intake manifold that faces that way.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #18August 23, 2010, 11:17:48 pm
Powered by Spearco
  • 1203
« Reply #18 on: August 23, 2010, 11:17:48 pm »
The intercooler fits perfect between the frame rails with the 2.5in.  90 bends.
2in. inlet and 2.5in. outlet. It gets really tight by the battery though.
G60 intake.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #19August 24, 2010, 04:39:12 am
« Reply #19 on: August 24, 2010, 04:39:12 am »
What width is that one PBSpearco? I am looking at some one is 27" X 5.5" X 2.25 and the other is 28x5.5x2.5. That is overall length and it will be in a MK II Jetta with A/C eventually. I was going to try lower and in front of the condenser. If it fits like yours though I would be very pleased.
Reply #20August 24, 2010, 05:30:34 am
gldgti
  • 488
    • http://scramjetsite.8m.com
'91 Golf Cabrio 1.9TD
Reply #21August 24, 2010, 07:08:19 am
GEE-BEE
  • 1604
« Reply #21 on: August 24, 2010, 07:08:19 am »
Hey GLTDi
2' is how it fit so well
This is the same way I wish to plumb my IC
Cheer's to you !
GB
« Last Edit: August 24, 2010, 07:46:40 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #22August 24, 2010, 10:00:17 am
honda_is_the_best
  • 104
« Reply #22 on: August 24, 2010, 10:00:17 am »
GB
that intake is pure sex..
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Reply #23August 24, 2010, 01:02:20 pm
Powered by Spearco
  • 1203
« Reply #23 on: August 24, 2010, 01:02:20 pm »
Got the measurments of the intercooler. 29"x 6"x 2.5". That left me room for the 90's on each end to fit between the frame horns.
I'd go taller but it was free, so I built with what I was delt with. I wouldn't go more than 10" tall because of the hood latch. If you use a taller on, you need to take off some metal off from the front support as to make it sit flat against the core support.
'13 Golf R:. Tuned
'98 Puch G320
Reply #24August 24, 2010, 04:13:59 pm
bugnut
  • 89
« Reply #24 on: August 24, 2010, 04:13:59 pm »
GB
If you are talking about my intake yeah that was a pain to build.  Took about 35hrs of fab work.
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #25August 24, 2010, 04:41:34 pm
Thezorn
  • 381
« Reply #25 on: August 24, 2010, 04:41:34 pm »
that is a beauty intake. defiantley jealous. How much more flow can you feel it gets compaired to stock?
Compounded 93 AAZ
Reply #26August 24, 2010, 05:50:57 pm
GEE-BEE
  • 1604
« Reply #26 on: August 24, 2010, 05:50:57 pm »
Look's like a 28 x5.5 x 2.5 Inter cooler with 2' Inch outlets for me
I will have to make a 45 degree  elbow 1.50 x 2.00' reducer  to come of the turbo ( ko3) to the pipe
or
I might try a 1.50 x 2.00 reducer straight, and get a 45 2' 45 degree pipe for 14.00.
This will get off the turbo with a downward bend to the rh front 90 degree elbow
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #27August 24, 2010, 08:11:38 pm
erice1984
  • 263
« Reply #27 on: August 24, 2010, 08:11:38 pm »
Yeah, definitely need to figure out something for the intake manifold.  I want the air to flow in from the drivers side.
1980 Rabbit 1.9TD
Reply #28August 24, 2010, 08:16:19 pm
GEE-BEE
  • 1604
« Reply #28 on: August 24, 2010, 08:16:19 pm »
Cheap: flip the inlet around
PD150 with racepipe
passenger performance used
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #29August 24, 2010, 09:15:10 pm
erice1984
  • 263
« Reply #29 on: August 24, 2010, 09:15:10 pm »
will a gasser intake manifold fit with a T3 turbo?
1980 Rabbit 1.9TD
