pics of fmic install on mk1 rabbit? anyone?
Pages:
Topic: pics of fmic install on mk1 rabbit? anyone? (Read 16590 times)
Reply #30
August 24, 2010, 09:30:13 pm
Powered by Spearco
Re: pics of fmic install on mk1 rabbit? anyone?
Reply #30 on:
August 24, 2010, 09:30:13 pm »
Yes it will. Only with the right ex. manifold.
I'm using a T3 turbo from a Merc. 300TD bolted to an ebay ex. manifold all mounted in a VW truck.
The underside of the gasser intake, depending if its a MK1 or MK2, needs to be clearanced.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #31
August 24, 2010, 09:33:03 pm
erice1984
Reply #31 on:
August 24, 2010, 09:33:03 pm »
was looking at a digi from a 91 fox.
the factory exhaust "log" manifold wont work?
Something like this:
http://cgi.ebay.com/ebaymotors/VW-8V-CAST-IRON-TURBO-EXHAUST-MANIFOLD-GOLF-JETTA-T3-/280552131590?pt=Motors_Car_Truck_Parts_Accessories
Last Edit: August 24, 2010, 09:36:37 pm by erice1984
1980 Rabbit 1.9TD
Reply #32
August 24, 2010, 09:53:20 pm
Powered by Spearco
Reply #32 on:
August 24, 2010, 09:53:20 pm »
As fas as the factory log manifold. Which one.
Yep, thats the same one I'm running, but coated inside and out.
'13 Golf R:. Tuned
'98 Puch G320
Reply #33
August 24, 2010, 10:00:56 pm
erice1984
Reply #33 on:
August 24, 2010, 10:00:56 pm »
awesome.. digi gasser intake and ebay ex manifold..
just got to find t3 with correct square flange.
like this manifold
1980 Rabbit 1.9TD
Reply #34
August 24, 2010, 10:11:04 pm
Powered by Spearco
Reply #34 on:
August 24, 2010, 10:11:04 pm »
That manifold is from a AHU TDI. It uses a GT15 turbo. Of corse you could make an adapter, but if your going that far, may as well build a custom one for what you want, where you want.
'13 Golf R:. Tuned
'98 Puch G320
Reply #35
August 24, 2010, 10:14:38 pm
erice1984
Reply #35 on:
August 24, 2010, 10:14:38 pm »
What did you do for waste gate? Use internal or external?
1980 Rabbit 1.9TD
Reply #36
August 24, 2010, 10:27:24 pm
Powered by Spearco
Reply #36 on:
August 24, 2010, 10:27:24 pm »
The turbo has an internal wastegate. Opens at 11.5 psi.
'13 Golf R:. Tuned
'98 Puch G320
Reply #37
August 25, 2010, 08:25:41 am
honda_is_the_best
Reply #37 on:
August 25, 2010, 08:25:41 am »
Quote from: erice1984 on August 24, 2010, 09:15:10 pm
will a gasser intake manifold fit with a T3 turbo?
only with a VNT manifold. and that happens to be the intake im running, they rock for stock VW manifolds.
VW it aint just a car, its a way of life..... Boost, Soot, Repeat
Pages:
