Author Topic: The Rebirth of Smokey Eddy - The 1.9 Saga  (Read 52176 times)
Reply #210May 04, 2012, 07:32:46 pm
Re: The Rebirth of Smokey Eddy - The 1.9 Saga
« Reply #210 on: May 04, 2012, 07:32:46 pm »
I thought you were showing off your 35 psi of boost :-\
LoL! You so funny.
As I told you earlier Edna my brother and I have the same set :) they are rockin for the price. He is actually working on a 1.9 swap himself!! GONNA BE AWESOME!
Reply #211May 05, 2012, 11:26:37 am
« Reply #211 on: May 05, 2012, 11:26:37 am »
you got an AAZ, and a big stereo dont you?
then you need a TDI/VR6 120a alternator..
boy, lemme tell you what! that 120a alternator is AMAZING..
my stereo has ALWAYS dimmed the lights in my car when you got it turned up..
even with 2 batteries hooked up, it would still dim the lights decent..
but then i did a serpentine swap, and added that 120a VR alternator (with ABA alt pulley) to it, and now, my lights DO NOT DIM, even when listening to quick dubstep with really tight bass, it still just pours the power to the batteries..
the difference between the 65a and 90a is big, but the difference from a 90a, to a 120a, is HUGE!!
the VR alternator was the best mod ive ever done to my charging system, hands down..
and i know you, like me, run a big stereo too, with more than one amp, and LOTS of current draw..
anyways, if you want a bullet-proof charging system, go with the VR/TDI 120a alt, a good batt under the hood, a wheel chair deep cycle in the trunk, and a capacitor if you feel the need..
i run no capacitor in my system now.. i always used get noise thru my amps with a cap installed.. now the deep cycle, being ~2 feet from my amps, has all the reserve power they could want..
Reply #212May 05, 2012, 11:35:15 am
  • 3468
    • McScrubbins Body Wash
« Reply #212 on: May 05, 2012, 11:35:15 am »
I don't have the means to do a serpentine. I don't notice dimming lights or any issue with my set up. The volt meter also shows the alternator holds up fine. Never dips below what I see as 13.6+v. I spent a lot of money on it :(
If I had the 100 Watt Hella's, 135 Watt highbeams, a microwave on from the 600 Watt inverter and I was blasting the tunes... yeah then it probably wouldn't work.
