Author Topic: oil pan gasket??  (Read 6301 times)
April 07, 2010, 04:41:57 pm
westcoaster
oil pan gasket??
« on: April 07, 2010, 04:41:57 pm »
My oil pan gasket is leaking in several spots.
Do I buy a new gasket or goop it up with silicone RTV form a gasket and slap it back together...?
Dumb question but I'm tempted to just silicone the thing. Problem would be if I ever needed to take the pan off again for whatever reason. Cleaning the surfaces would be a PIA...
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #1April 07, 2010, 04:49:05 pm
truckinwagen
  • 1895
Re: oil pan gasket??
« Reply #1 on: April 07, 2010, 04:49:05 pm »
get a new gasket, RTV has no place as a gasket replacement.
if you can get the rubber gasket do that, then it is reusable.
83 Opel Kadett Diesel
Reply #2April 07, 2010, 05:13:27 pm
GEE-BEE
  • 1604
« Reply #2 on: April 07, 2010, 05:13:27 pm »
ANOTHER GASKET THAT SHOULD BE FROM REINFORCED SILICONE ...
I CAN MAKE IT FROM .020 OR .062....
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3April 07, 2010, 09:03:45 pm
« Reply #3 on: April 07, 2010, 09:03:45 pm »
Most people will hate you for thinking such a thing ;) haha.
Reply #4April 09, 2010, 08:38:49 am
kaneb
  • 164
    • www.dasdubbers.org
« Reply #4 on: April 09, 2010, 08:38:49 am »
isn't a oil pan gasket like 15$?  Buy a new one.  I would upgrade and spend alittle more then the 15 and get a rubber one and say good bye to a leaky pan.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #5April 09, 2010, 09:06:21 am
zagarus
  • 619
« Reply #5 on: April 09, 2010, 09:06:21 am »
or step it up another notch and get a windage tray with the rubber gasket built in :D
Reply #6April 09, 2010, 08:07:08 pm
westcoaster
« Reply #6 on: April 09, 2010, 08:07:08 pm »
I'm in Canada eh!
Our prices are a little higher than that.... :P
Ok,ok,ok..... I'll set the tube down and go look for a gasket this weekend.
Reply #7April 09, 2010, 08:09:24 pm
« Reply #7 on: April 09, 2010, 08:09:24 pm »
I've seen many engines totally ruined by RTV. It's horribly wonderful stuff.
Reply #8April 09, 2010, 10:20:20 pm
Runt
  • 83
« Reply #8 on: April 09, 2010, 10:20:20 pm »
Maybe a dumb question, but do these come stock in some application, or are they aftermarket?
What is the application or source?
Thanks
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #9April 09, 2010, 10:44:50 pm
mystery3
  • 774
« Reply #9 on: April 09, 2010, 10:44:50 pm »
Reply #10April 10, 2010, 07:29:51 am
« Reply #10 on: April 10, 2010, 07:29:51 am »
They come stock on the AAZ
Reply #11April 10, 2010, 12:08:09 pm
westcoaster
« Reply #11 on: April 10, 2010, 12:08:09 pm »
Forgive me for asking a totally silly question, but I would guess an AAZ is a 1.9td out of a what? 1996 jetta?
(get the windage tray and the rubber gasket all in one right?)
Makes getting one from the parts store a whole lot easier...
Just got back from uap napa. No listing for a rubber gasket for an '87 diesel. They only had cork and thin paper.
Reply #12April 10, 2010, 02:42:24 pm
« Reply #12 on: April 10, 2010, 02:42:24 pm »
AAZ is G/J 93-98
P 92-96 (I think)
The rubber gasket is built into the windage tray.
Reply #13April 10, 2010, 04:34:26 pm
410
  • 581
« Reply #13 on: April 10, 2010, 04:34:26 pm »
Altrom also carries them.  That's where I got mine and uap also buys from altrom.  The altrom part#037 115 220b will also work at napa.  Hope this helps!
Reply #14April 10, 2010, 08:55:01 pm
  • 3468
    • McScrubbins Body Wash
« Reply #14 on: April 10, 2010, 08:55:01 pm »
I bought my oil pan gasket from bestpriceautoparts.com
or is it .ca?
but likewise a windage tray is never a bad idea!
