Author Topic: oil pan gasket??  (Read 6715 times)
Reply #15April 10, 2010, 11:16:53 pm
  • 2932
Re: oil pan gasket??
« Reply #15 on: April 10, 2010, 11:16:53 pm »
To find a rubber oil pan gasket I think I looked for a gasket from a '97 Golf,
 2.0 engine.
Reply #16April 10, 2010, 11:19:54 pm
truckinwagen
  • 1895
« Reply #16 on: April 10, 2010, 11:19:54 pm »
yep, the ABA oil pan and valve cover are re-usable rubber, and fit the diesel without modification.
83 Opel Kadett Diesel
Reply #17April 11, 2010, 06:02:57 am
« Reply #17 on: April 11, 2010, 06:02:57 am »
You have to change VC studs for the rubber VC gasket though.
On the Oil pan rubber gasket do you need to change anything or does it have reinforcements built in?
Reply #18April 13, 2010, 03:45:15 pm
westcoaster
« Reply #18 on: April 13, 2010, 03:45:15 pm »
The rubber valve cover gasket could be a good thing... :)
What ou change the studs to? bolts?
Reinforcements on the oil pan gasket? is that to make it stiff rather than floppy?
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #19April 13, 2010, 03:50:28 pm
rallydiesel
  • 1880
« Reply #19 on: April 13, 2010, 03:50:28 pm »
You don't have to change anything. I have a rubber oil pan gasket on my 1.6. Works great.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #20April 13, 2010, 03:51:01 pm
truckinwagen
  • 1895
« Reply #20 on: April 13, 2010, 03:51:01 pm »
yeah, you do need to do the studs.
there are studs that dont have a shoulder that work, but I just swapped to allen head bolts.
the rubber oil pan gasket is a direct swap, and it does have reinforcement in it I believe.
Reply #21April 13, 2010, 03:52:07 pm
zagarus
  • 619
« Reply #21 on: April 13, 2010, 03:52:07 pm »
get studs from a 2.0l ABA gasser head if you want to convert to a rubber valve cover gasket...They dont have the shoulders like a stock diesel stud has because the gasket has metal spacers built in.
Reply #22April 13, 2010, 10:06:50 pm
  • 2932
« Reply #22 on: April 13, 2010, 10:06:50 pm »
Long set screws work great,
 the allen head makes them easy to install.
