building an MHDi ( MTDi ) 2.2hdi
by
famous phil
on 29 Mar, 2010 21:14
Just thought I'd post some pics of some engine conversions that I've been doing since the early nineties
at the moment there's a breakers I know well and have a load of damaged cars PSA's HDi's I can buy a low milage HDi without injection system for £100 , , So all I need to do is design an injection system for the job ,,,,
The campers below are fitted with = red one 12valve 2.1td we'll be changing the pump to bosch at the weekend ,, the other blue camper is fitted with a 306DTurbo engine xantia inlet manifold running underslung intercoolers ,
if all goes well will build an MTDi / MHDi for the 305 van
#1
by
snakemaster
on 30 Mar, 2010 15:49
MTDI pug hdi i would love to see that pug idi injector brake psi 140 bar , hdi 2000 bar ish and the hdi is about 7 stage injector too,
the pug engine sits in there nice , 1z tdis are cheap now
#2
by
famous phil
on 03 Apr, 2010 01:43
1Z's are cheap now some friends have these in there campers and to make them go as well as my Peugeot powered campers means the life is greatly shortened = I've built some hybrid injection pumps using pumps collected up from later VW TDi's 220/300bar , these had rods through the block or cracks in the block behind the flywheel so parts were really cheap ,these parts will be great to power the direct injection HDi , for these injectors to fit the HDi cylinder head 0.8mm to a depth of about 15mm then about 1.4mm to a further depth about 6mm needs machining , the lower portion is identical ,
#3
by
snakemaster
on 11 Apr, 2010 04:56
if you got a bit of spair time i would make or get a pump bracket to bolt on to the hdi engine to take the landrover 200/300 tdi ve bosch pump and put the 300 injectors on to , you will need the same size cam pully (on hdi)to fit the bosch pump and maby a extra tencher/idler , the pump would need tweeked up for max revs/ power, injector spray patern may be a problem, 300tdi injectors are 230bar not shure the nozzle size
#4
by
Turbinepowered
on 12 Apr, 2010 20:21
Forget the engine, I want that 305 van!
#5
by
famous phil
on 24 Apr, 2010 14:46
I've been building mechanically operated pumps - Bosch electronic type pumps like fitted to the VW TDi , I've built the pump and have some injectors from a BMW to fit the HDi engine
the pump bracket I'm going to use is from a pug D turbo engine
The pug van above is to be fitted with a HDi gearbox and 2.1 bottom end I think - just picked an engine up today , it took plenty of searching to find a 305 van this good , now has PAS and lecy windows
, just like another pals that had been a local delivery van warehouse stored fitted with 1.9TD ,
#6
by
darrenjlobb
on 30 Apr, 2010 15:23
Does the XUD mecanical pump bracket bolt right on to the DW10 HDI motor??
#7
by
famous phil
on 03 May, 2010 01:06
Hi, I've not actually tried bolting one on yet , I've looked at the casting and believe it will bolt on , I'll try one on as soon as I get chance
which is going to be very soon- blew head gasket on DTurbo engine due to boost gauge giving wrong reading and me turning boost up , I fitted another gauge and was hitting over 25psi
#8
by
darrenjlobb
on 06 May, 2010 03:54
Heh i see 35psi daily on my XUD...
#9
by
famous phil
on 15 Jun, 2010 15:57
#10
by
famous phil
on 07 Jul, 2010 16:29
#11
by
snakemaster
on 14 Jul, 2010 06:51
some nice work there what injectors did you fit to get her going , does the hdi engine have the same cc cup in the pistons as the vw tdi ,what is the CR of the hdi. what power you hoping to get
#12
by
dts67
on 18 Jul, 2010 08:32
Great work mate, really admire this.
#13
by
famous phil
on 12 Aug, 2010 03:19
Hi, I've tried a couple of different injectors from BMW 320 to early transit connect , piston crowns are similar to vw tdi , compression ratio of this engine is 18.00:1 a 2.2hdi that I'm also building is slightly lower at 17.60:1 , the 2.0L hdi I'm building it to be a realistic 120bhp with 196ft lbs , In a pals unit sits a very clean 305 estate that the 2.2hdi might get fitted to , I'm after a lot of power from this engine
