Author Topic: 1.9 IDI, TDC - Question.  (Read 2723 times)
January 27, 2010, 08:55:06 am
ein bora
  • 377
« on: January 27, 2010, 08:55:06 am »
Just finished installing my rebuilt Giles pump after having some timing issues. My flywheel has two TDC timing marks. Oddly I can get the pump to run on both? Does anybody have any idea as to which one I should be using??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1January 27, 2010, 10:59:47 am
Powered by Spearco
  • 1203
Re: 1.9 IDI, TDC - Question.
« Reply #1 on: January 27, 2010, 10:59:47 am »
From what I remember about the two marks is that one is a 6deg. before TDC and the other is the 0 for TDC. The 6deg. has a diamond shape notch, the 0 is dot.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #2January 27, 2010, 12:55:28 pm
lovinthedeez
  • 489
« Reply #2 on: January 27, 2010, 12:55:28 pm »
nope.  the diamond is the tdc and the 0 is the 6dbtdc
Reply #3January 27, 2010, 06:38:12 pm
« Reply #3 on: January 27, 2010, 06:38:12 pm »
I think it depends on the style of flywheel you have. Most diesels have a diamond at TDC, although I have also seen a 0. Thumbs up for Germans.
Reply #4January 27, 2010, 09:30:41 pm
Powered by Spearco
  • 1203
« Reply #4 on: January 27, 2010, 09:30:41 pm »
Well if your looking at a flywheel that has two timing marks, then 0 would have to be TDC. If you still can't find a true TDC mark, the make a degree wheel of some sort a find it that way, I'm sure theres other ways of finding TDC .
'13 Golf R:. Tuned
'98 Puch G320
Reply #5January 27, 2010, 09:57:17 pm
lovinthedeez
  • 489
« Reply #5 on: January 27, 2010, 09:57:17 pm »
then why does the dimple (or 0) arrive before the diamond?
Reply #6January 27, 2010, 10:29:47 pm
« Reply #6 on: January 27, 2010, 10:29:47 pm »
Perhaps someone's installed a gasser flywheel... they are marked like this:
Reply #7January 27, 2010, 11:07:38 pm
lovinthedeez
  • 489
« Reply #7 on: January 27, 2010, 11:07:38 pm »
inserts foot into mouth :D
