clutched water pump pully on 1.9 aaz, how do you test it?
Topic: clutched water pump pully on 1.9 aaz, how do you test it? (Read 3946 times)
January 25, 2010, 09:26:31 pm
madrogers
January 25, 2010, 09:26:31 pm »
got this w/p pulley, how do i know if is working, is there a way to test it , very littel resistance turning ether way by hand. And what the deal on a clutched pully, heard of them the alt. but not the w/p.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
January 30, 2010, 02:32:51 pm
rallydiesel
Re: clutched water pump pully on 1.9 aaz, how do you test it?
January 30, 2010, 02:32:51 pm »
I seriously doubt that is a clutched pulley. I would assume it's an idler pulley combined with the actual water pump pulley.
1991 Jetta TD - sold
2001 Golf TDI - Son's
January 30, 2010, 08:05:35 pm
G60ING
Corrado TDI
January 30, 2010, 08:05:35 pm »
I bet it looks like the multi piece water pump pulley on the Rallye. Its not a clutch. Its a just an over priced complicated jig saw puzzel.
here are some waterpulleys for you:
http://forums.vwvortex.com/zerothread?id=244434
January 31, 2010, 07:42:46 pm
madrogers
January 31, 2010, 07:42:46 pm »
this is a pic of the pulley (I hope pic is pasted,will try again if not), I can spin the outer part separate from the inner part , may be it is not clutched and just not pressed together properly? i am not familar with it.
January 31, 2010, 11:28:46 pm
svenakela
January 31, 2010, 11:28:46 pm »
There are clutched water pump pulleys, my VW Touran got one for sure. It's there to cut emissions, better cold start power etc.
http://www.amazon.com/Universal-Clutch-Water-Pulley-Holding/dp/B000RT924E
http://www.sae.org/technical/papers/2007-01-4260
February 01, 2010, 06:44:13 pm
February 01, 2010, 06:44:13 pm »
That looks like a 1.6 alternator/Wp setup.
February 01, 2010, 09:13:39 pm
madrogers
February 01, 2010, 09:13:39 pm »
yes it is a pully off a 1.6 t/d apx 1992, just looking to find out if is still good? not much resistance in turning it both ways. how can i tell or test it , what do i look for??
February 01, 2010, 10:24:56 pm
Powered by Spearco
February 01, 2010, 10:24:56 pm »
They make noise when the bearing goes bad. Its a idler pully for AC, and for PWR. steering.
The two belts spin at different ratio's, so one free wheels.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
February 01, 2010, 10:33:11 pm
February 01, 2010, 10:33:11 pm »
Aha.... so in the picture the OP must be missing a belt that would normally go to powersteering and A/C.... makes sense now.
Last Edit: February 01, 2010, 10:39:07 pm by Vincent Waldon
February 02, 2010, 08:17:02 am
madrogers
February 02, 2010, 08:17:02 am »
yes that all make sense now , thanks for the rply/ info . sometimes working from a box-o-parts makes things a bit difficult.
