Author Topic: rebuilding injectors  (Read 2095 times)
June 03, 2009, 06:22:30 am
Dasherhead
  • 8
« on: June 03, 2009, 06:22:30 am »
In Vince's great writeup on rebuilding injectors he places sandpaper on glass and laps surfaces.  Is that water on top of the sandpaper?  Help me out here - I want to get this one right!  BTW - this is a great site for learning!   :)
79 Dasher Wagon / 06 Jetta Tdi / 81 Rabbit L
Bend, Oregon
Reply #1June 03, 2009, 06:38:26 am
Re: rebuilding injectors
« Reply #1 on: June 03, 2009, 06:38:26 am »
Welcome to the site!
It's a generic light oil... probably some 5W30 from my gasser days.  ;)
As the instructions say... the "proper" tool is a precision microtome or a very fine green lapping block.  Sandpaper is kinda cheating,  so the trick is to do as little as needed after having a close look at how out-of-whack the surfaces are.
Reply #2June 03, 2009, 11:02:31 am
cyrus #1
  • 360
« Reply #2 on: June 03, 2009, 11:02:31 am »
I've had good luck using those peel and stick sanding discs.  They stick quite nicely to a sheet of glass.
About the only thing I do differently than Vince is the motion used for lapping.  I use a figure 8 motion and rotate the part 90° every couple seconds.  This method seems to virtually eliminate any chance of wearing the part unevenly.  :)
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #3June 03, 2009, 04:39:31 pm
Rabbit TD
  • 840
« Reply #3 on: June 03, 2009, 04:39:31 pm »
The only thing there though is that can you get them in a 400-600 grit or finer and are they the wet or dry style and hold up to the oil very good?
Reply #4June 05, 2009, 12:47:59 am
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: June 05, 2009, 12:47:59 am »
i ALWAYS use oil with wet dry for fine sanding like injector internals.
ALWAYS...
wet dry i would say is re-usable. The grit obviously goes down after exended use but used correctly and carefully it can last a very long time. escpecially tapped to a piece of glass.
