Author Topic: The all-encompassing Turbo Oil drain/feed line thread  (Read 52532 times)
Reply #15May 27, 2009, 06:16:14 pm
Re: The all-encompassing Turbo Oil drain/feed line thread
« Reply #15 on: May 27, 2009, 06:16:14 pm »
I am going with something like this for the return and probably stainless brake line for the feed.
Reply #16May 27, 2009, 07:30:38 pm
« Reply #16 on: May 27, 2009, 07:30:38 pm »
oooooooooh... thats a sexy drain tube in the making.
Reply #17May 27, 2009, 08:04:53 pm
hamradio
  • 282
« Reply #17 on: May 27, 2009, 08:04:53 pm »
I also would advise against the long oil drain running into the vac return.  Not a good situation going on there, IMO.  I'm honestly surprised that actually works, after my oil drain experiences.
Here's what I made for my VNT15 on a 1.6.  It is the third or fourth design, after putting up for a year with marginal oil drains I had made that either leaked, didn't flow well enough, or ran into the axle.
I tig welded a bung onto the oil pan for it.  I have a brass 90* 3/4" pipe thread elbow, and a 3/4" pipe-3/4" hose male adapter in that elbow.  The drain pipe I made from 1/2" electrical conduit, bent with the aid of a torch.  There is about a 1/8-1/4" gap between the pipe and nipple, and they line up perfectly.  I have a piece of oil resistant hose connecting the two, in the style of some of the dodge cummins trucks.  It works excellent, and does not leak at all.  I spent about 3 hours getting it bent perfectly, ha.
Reply #18May 27, 2009, 08:21:40 pm
« Reply #18 on: May 27, 2009, 08:21:40 pm »
i cut the top half off the 1.6 line right above the flex fitting. and i had the flange for the turbo drain. so i connected the drain pipe to the flange with some rubber oil hose and put a couple hose clamps on it. works great, has yet to leak.
Reply #19May 27, 2009, 08:49:58 pm
TD100
  • 16
« Reply #19 on: May 27, 2009, 08:49:58 pm »
Feed line: An old paintball air line w/ quick disconnects on both ends, just because the fittings (1/8"-27) screwed into the VNT's side. I then just drilled/tapped the oil filter housing for the same threads.
Return line: Drilled a hole in the pan and welded a 3/4" coupling into it. Then used a 3/4" 90 degree fitting w/ a 3/4" barbed to accept a piece of hose w/ clamps. I used the original stainless braided line from the VNT, which I hosed clamped to the hose using the large bolt that would normaly screw into the TDI's block. Works well -no leaks. Don't have any good photos showing the return braided line though.
http://www.geistsystems.com/slides/IMG_1269.html
http://www.geistsystems.com/slides/IMG_1267.html
http://www.geistsystems.com/slides/IMG_1268.html
« Last Edit: May 27, 2009, 08:51:39 pm by TD100 »
-Rich
 '93 Toyota T100. R150 5-speed, 1.6 w/ vnt15, inter cooled and 2.5" exhaust.
Reply #20May 27, 2009, 08:51:28 pm
« Reply #20 on: May 27, 2009, 08:51:28 pm »
the return line on my turbo was really short, and a right angle. it had a block oil drain.
Reply #21May 29, 2009, 05:38:06 am
arb
« Reply #21 on: May 29, 2009, 05:38:06 am »
i wonder if that drain setup works? im really not trying to rip on the owner of that setup, but that is nothing i would ever put on my car. i would have just poked a hole in the n/a oil pan and welded a bung on there. it would have been so easy, and probably cost about the same as all the heater hose and brass fittings. plus, probably would have taken about the same time to make it.
No slam taken. :-D  I agree it does not look the best, but it does work. I also had a couple other engineering challenges - the turbo I have has a larger oil drain flange than the stock return line, so I could not just bolt it up. Also, my CV shafts have a different length and maybe placement than in a VW, so I was not sure I'd have clearance. This weekend I will be looking at changing both of these. It could be I just keep using what is working.
Reply #22May 29, 2009, 06:31:51 am
Rich_91
  • 21
« Reply #22 on: May 29, 2009, 06:31:51 am »
I heard someone using 5/16ths brake line for the feed
I have personal experiance with using brake line, not on my VW turbo, but on a different turbo build. The brake line was cheap, fittings were fairly easy
to find, and it sealed up well.
The problem was that, in my instance, vibration caused the line to crack, right at the base of the flare. I tried putting a loop in the line to deal with it, but it just extended its life a little bit. Lasted a few weeks, but would always shake itself apart, and never at a good time  :P
Eventually I went to the local hydrolic shop, told them what I needed and they made up a braided line with ends that I requested. IIRC it was like $35. The brake line was cheap, but it was alot of screwing around, and when it broke the first time, I almost buggered a turbo.  .
And if you are using rubber lines for your drain / return, make sure they are silicone / some kind of oil resistant stuff, or at least of good quality. I tried that too, and used cheap heater hose. The hose swelled up after a few weeks and slid off. I cought it before I had any significant loss of oil, but it made a hellova mess of the engine bay, and the hose was hard to replace.
Just my .02 :D
« Last Edit: May 29, 2009, 06:34:17 am by Rich_91 »
My Fleet
91 VW Jetta 1.6td.  310K+  My Daily
90 Dodge Ram 50 2.4 turbo (my toy)  250K+
94 Eagle Talon Tsi AWD. 205K+  Another Project!
Reply #23May 29, 2009, 08:37:02 am
saurkraut
  • 904
« Reply #23 on: May 29, 2009, 08:37:02 am »
I'm going to try NAPA P/N H178 1/2" fuel line hose.  The stock steel drain line is 15mm (0.5905") so hopefully the 1/2" hose will stretch over it.  I put a 3/8" spacer under my turbo to accommodate the bigger K26 compressor, so I have to lengthen the stock drain hose.
Anyone ever removed the flex section from the stock drain hose?  If so, is there a barb in there?
« Last Edit: May 29, 2009, 08:46:10 am by saurkraut »
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #24May 29, 2009, 09:12:55 am
« Reply #24 on: May 29, 2009, 09:12:55 am »
no barb, just a straight fitting. take a grinder with a cut off wheel and make score marks all the way around. then that gives the hose some traction so it stays put and doesnt pop off.
Reply #25May 29, 2009, 09:28:33 am
saurkraut
  • 904
« Reply #25 on: May 29, 2009, 09:28:33 am »
Thanks!
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #26May 30, 2009, 04:39:33 pm
macka
  • 957
« Reply #26 on: May 30, 2009, 04:39:33 pm »
Half inch is 13 mm
Quote from: Vincent Walden
Reply #27May 30, 2009, 05:26:50 pm
« Reply #27 on: May 30, 2009, 05:26:50 pm »
I'm going with 5/16 brake line, the local napa had the adapters to get down to 1/8 pipe.
I'll find a way to support it so hopefully it won't crack, after all, IP lines are steal and as long as the clamps are in place they last forever.
Reply #28May 31, 2009, 05:54:33 am
saurkraut
  • 904
« Reply #28 on: May 31, 2009, 05:54:33 am »
Half inch is 13 mm
Yes it is.
Actually, .5" is 12.7mm
My options for large diameter fuel line (oil resistant) are 1/2" or 5/8".  So the choice is stretch the half inch over the 15mm (.5905") or try to calmp down the 5/8" (.625").
Sucks, don't it....
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #29May 31, 2009, 11:23:50 am
macka
  • 957
« Reply #29 on: May 31, 2009, 11:23:50 am »
too bad they didn't make 9/16" for you. I know that there is 9/16" hydraulic hose but I'm not sure how well it would work for you.
