Author Topic: Vnt-15 installation, slowly but surely.....almost  (Read 36285 times)
Reply #75October 11, 2009, 10:58:19 pm
Re: Vnt-15 installation, slowly but surely.....almost
« Reply #75 on: October 11, 2009, 10:58:19 pm »
Yeah that's what I thought too ::) I do know that at tdc the valves will open about halfway before hitting the piston. I found that out from adjusting the clearance and trying to push the lifters down with the crank at tdc ::)
I don't know what else to check next.......maybe see if the wheels are sticking into the housings enough or something. ::)
« Last Edit: December 27, 2009, 10:55:58 pm by rabbitman »
Reply #76October 12, 2009, 09:31:26 am
« Reply #76 on: October 12, 2009, 09:31:26 am »
you need to be getting over 25 psi with that thing. my car is a rocket and i dont have the vanes hooked up at all. i really should hook them up.
Reply #77October 16, 2009, 06:54:55 pm
sootyperry
  • 20
« Reply #77 on: October 16, 2009, 06:54:55 pm »
obviously you have a problem with you turbo. unfortunate that you spent alot of money without doing your research first. fortunately you have your oil and air/exhaust plumbing sorted. why not try a different turbo vnt or otherwise to get your boost on say a junkyard turbo? contact prothe about your incompatibility issue.
Reply #78July 09, 2011, 04:34:05 pm
wdkingery
  • 494
« Reply #78 on: July 09, 2011, 04:34:05 pm »
well what ever happened here?
and what did you do about your rear, passenger's motor mount to make this thing fit?
and what about the oil drain?
Reply #79July 09, 2011, 11:36:53 pm
« Reply #79 on: July 09, 2011, 11:36:53 pm »
Yanked the turbo, the current configuration is in my sig.
MK1's don't have that problem but either way this is the euro style vnt with the removeable manifold and it sits higher up so it would probably work fine with a MK2.
Threaded/brazed a 90 degree street (I think) pipe fitting into the oil pan and used a short chunk of hose and a flange that I made.
Some day I want to get the turbo professionally tested/repaired and try again but for now I'm doin' fine.
Reply #80July 10, 2011, 02:58:40 pm
wdkingery
  • 494
« Reply #80 on: July 10, 2011, 02:58:40 pm »
Where the hell am I gonna get a euro vnt?? Anyway I have a vnt I'm just gonna cut my mount I got one from the junkyard today.. Just need to figure my oil lines. An find out if a 2.0 intake manifold will work (of course not) or if a longitudinal mounted 85 fox intake will work.. Then I'm boltin on. Even if I only get 5 psi I'm only doin it for to sound mostly an hopefully a few more mpg
