Author Topic: Pictures of your mk2 Turbodiesels  (Read 54274 times)
Reply #60February 25, 2009, 03:50:26 pm
foxracer1
  • 991
« Reply #60 on: February 25, 2009, 03:50:26 pm »
Quote from: "zagarus"
the dead diesel. Being revived as a 1.9td coupe.
I cried. :cry:
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #61February 26, 2009, 12:52:42 pm
arb
« Reply #61 on: February 26, 2009, 12:52:42 pm »
WOW !!! Is this a 4x4 diesel we can't have in the US until its 25 years old ???  (Unless we know a military person stationed in Europe that we trust enough to give them $$$ to buy the car, and then keep it for 1 year after they import it here for free)
I want one !!
Reply #62February 26, 2009, 12:56:15 pm
flapjack
  • 283
« Reply #62 on: February 26, 2009, 12:56:15 pm »
i thought they only came as a 1.8 gas but from:
http://germancarscene.com/2007/12/23/ebay-find-of-the-day-volkswagen-golf-country/
Unless you frequent VW shows, there’s a pretty good chance that you won’t have seen a Golf Country in the flesh. Designed for light off-road driving, it had more suspension travel, four-wheel drive, bullbars, and a skidplate for protecting the engine area. In Europe it was offered with the acclaimed 114bhp (85 kW) 1.8 8v petrol engine, and in smaller numbers, the 75bhp (56 kW) 1.6 GTD turbo diesel engine.
signature
Reply #63February 26, 2009, 01:47:49 pm
flapjack
  • 283
« Reply #63 on: February 26, 2009, 01:47:49 pm »
my car
not coming out till it's running
signature
Reply #64February 26, 2009, 02:44:52 pm
arb
« Reply #64 on: February 26, 2009, 02:44:52 pm »
Quote from: "flapjack"
Looks like I know where the Russians copied their 4x4 from now, except the diesel part - they have no clue on small diesel engines. They ran out of cash when they were to pay the $100M or so for their half VM Motori this month. GM bought the other half from Detroit Diesel last year for their cars in the rest of the world. Anyway, here a photo of what I saw in Ukraine. Sorry for the low quality. The 3D camera sometimes did this. This image you can get 3D w/o glasses if you hold your finger up in the middle of the 2 halfs and slowly bring it to your nose.
Reply #65March 01, 2009, 05:43:39 pm
gigaz2
  • 626
« Reply #65 on: March 01, 2009, 05:43:39 pm »
february 1984 Golf "C" 1.6TD made in Wolfsburg, bought for 300€ from a friend
mods so far:
angel eyes (lol, yes there are some cosmetic details as well)
sway bar
mk3 subframe
Seat Ibiza TDI rear engine mount
mk3 vr6 driveshafts, steering components... the lot
Powerflex poliutherane bushes everywhere (except the rear that isn't done yet)
mk3 vr6 5*100 15" BBS wheels on 185/55/15 rubber (calipers almost touch the rims ;) )
Passat vr6 288mm vented discs (ABS/EDC being plugged in)
Passat vr6 226mm rear discs
Passat vr6 23.8mm brake master cylinder with ABS module
pump: 10mm head on 1.9TD cam, mild gov mod done
Ford Mondeo 1.8TD 90hp Lucas injectors
deleted diverter valve
new everything, bolts, washers, all VW original
a lot more that I forgot...
the engine (1.6TD mech) is under serious surgery right now, so no engine pics
I have big plans for this shell: (not on the near future)
2.5L inline 5 TDI engine, custom cam, valves, exhaust....
 GT2556V turbo, custom intake.... the works
Reply #66March 01, 2009, 06:18:11 pm
« Reply #66 on: March 01, 2009, 06:18:11 pm »
Quote from: "arb"
wow thats freaky cool  :lol:
as for the golf country, there are very few of them left apparently.  they only built a small amount, most of which aren't on this continent  :cry:
Quote from: "gigaz2"
the first thing i'd do with that exhaust manifold, is modify it. the cylinder closest to the exit point will be the first one to get ruined in the event of high EGT's.  the manifold isn't really that bad though... (compared to the 2.4L toyota diesel exhaust mani) but you'll need a shoe horn to fit that into a rabbit  :lol:
Reply #67March 01, 2009, 06:38:51 pm
Jettagli16v
  • 344
« Reply #67 on: March 01, 2009, 06:38:51 pm »
Quote from: "arb"
The ILTIS came with a Diesel!
If you like that (using the Rallye golf syncro set up, if I recall)
Check out the ILTIS with a modified Quattro drivetrain
and a 1.6 diesel, sealed to be in up to 2-3 feet of water!
They say it is unstoppable..
Check this out:
http://classicunimogs.com/vw_iltis.html
-Brad
Reply #68March 01, 2009, 06:54:49 pm
gigaz2
  • 626
« Reply #68 on: March 01, 2009, 06:54:49 pm »
Quote from: "jtanguay"
I'm not using that one, I got another that bolts right up to the gt2556v ;) and the turbo sits on a more central place
totally true about the shoehorn, this block is 7cm longer :(
will have to get a compatible gearbox as well
Reply #69March 12, 2009, 12:10:16 pm
zozep
  • 176
« Reply #69 on: March 12, 2009, 12:10:16 pm »
.kuil
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M :(  DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
Reply #70March 14, 2009, 10:20:27 am
ryanp
  • 269
« Reply #70 on: March 14, 2009, 10:20:27 am »
The Mk2 Looks  8)  How do you mean Ibiza TDi engine mount? the later dogbone mount?
I've got a Mk3 GTi subframe and made this stiff mount:
I've also fitted a passat crossmember so i can have a very similar mount at the front too! if it's too stiff I'll drill some holes in the Pucks.
Mine, soon to be very similar spec to gigaz2 (nearly built, M-tdi going in!):
not many in tornado red i believe! there are not too many vans either!
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #71March 14, 2009, 01:13:14 pm
gigaz2
  • 626
« Reply #71 on: March 14, 2009, 01:13:14 pm »
really nice van!
its not the dogbone style mount, came from an 110hp tdi, swapped just because the mk2 and mk3 subframes differ, although both mounts bolt right up :D
VW = LEGO? :D
Reply #72March 14, 2009, 03:24:21 pm
ryanp
  • 269
« Reply #72 on: March 14, 2009, 03:24:21 pm »
I've got a Seat ibiza TDi sport 110 and i think the mounts seem REALLY soft, the engine moves around LOADS! the vibrations are better than a mk3 mount though!
I'm on with modding a big mount with some hokey pucks to make a stiffer gearbox side mount too.
The Van looks a bit different now, rolled and flared arches with no trims, mk4 golf steels with 195/45/15 uniroyal rainsports and I'm just on with clearing all the small patches of rust and stonechips
I think VW could persue LEGO for some sort of copyright infringement!!!!
I really fancy building a 1y diesel head with a 1.6TD bottom end and a VNT for a crazy revving diesel!
Ry
Reply #73May 23, 2009, 06:14:35 pm
Farmermike
  • 11
« Reply #73 on: May 23, 2009, 06:14:35 pm »
my £200 GTD after recent mods
Reply #74May 24, 2009, 12:31:33 am
juleshs
  • 49
Re: Pictures of your mk2 Turbodiesels
« Reply #74 on: May 24, 2009, 12:31:33 am »
lots more work to do yet
