Author Topic: 1.6TD to 1.9TD - noobie questions  (Read 7226 times)
Reply #15January 05, 2009, 04:34:24 pm
TurboJ
  • 661
« Reply #15 on: January 05, 2009, 04:34:24 pm »
1.6 TDs all have the same inlet and exhaust manifolds. The same are also used on early 1.9 TDs. Late model 1.9s will have different manifolds in which case you may not be able to use a 1.6 TD turbocharger.
The 1.6 TDs can have four different turbochargers from the factory.
KKK K14
Garrett T2
KKK K24
Garrett T3
The K14 and T2 are smaller than the other two, but also more modern.
Better suited to daily driving, but lacking in ultimate power output capacity.
K14 and T2 have similar dimensions and similar wheel diameters.
The K24 and T3 are the choice for a performance-minded, but they spool up slower than the smaller turbos.
K24 and T3 have similar dimensions and similar wheel diameters.
The 'big' turbos can usually be found on older 1.6 TDs and the 'small' turbos can be found on newer ones. There should always be a plate or etching on the turbo that tells the type code.
Jetta II 1.6 TD 'Project 200'
Reply #16January 05, 2009, 05:10:56 pm
Jasonsmack
  • 21
« Reply #16 on: January 05, 2009, 05:10:56 pm »
Do all the turbochargers fit onto the 1.6TD manifold without modification or adaper plates? I guess I am not really worried about what the 1.6 has, I need to know which manifolds work if I end up buying a KKK24 for the 1.9.
Reply #17January 05, 2009, 05:27:57 pm
TurboJ
  • 661
« Reply #17 on: January 05, 2009, 05:27:57 pm »
Quote from: "Jasonsmack"
Yes. Like I said, all 1.6 TDs have the same manifolds. So all 1.6 TD turbos are bolt on.
Good luck for your search! IMO the K24 is the one to go for!
Reply #18January 05, 2009, 11:33:42 pm
Jasonsmack
  • 21
« Reply #18 on: January 05, 2009, 11:33:42 pm »
I assume a T3/T4 hybrid is too large for any sensible daily driving on the 1.9 AAZ? I have a couple new ones kicking around here somewhere.
Reply #19January 06, 2009, 05:29:06 am
TurboJ
  • 661
« Reply #19 on: January 06, 2009, 05:29:06 am »
Sounds quite large, but what are the inducer/exducer diameters?
Reply #20January 06, 2009, 12:16:43 pm
Jasonsmack
  • 21
« Reply #20 on: January 06, 2009, 12:16:43 pm »
The turbine side has 2.2" inducer, 2.560" exducer. The compressor side is 2.250" inducer, 2.960" exducer. The A/R ratio on the compressor housing is .50. The ratio is not marked on the turbine housing.
The second turbocharger might be very slightly smaller but I do not have the housings off of it to do the measurements.
They look about twice the size of anything I have ever seen on a VW. I would think that the little VW would have a tough time spooling the turbos without revving the engine right out.
Reply #21January 06, 2009, 01:10:20 pm
TurboJ
  • 661
« Reply #21 on: January 06, 2009, 01:10:20 pm »
You're right, that's too big if you're not planning on a compund setup with a small turbo to complement the big one.
You can search for a used turbo from all kinds of industrial and agricultural engines - they have the right wheel combos as they're diesel engines (diesels need slightly bigger turbines than compressors), and they are usually also very tough.
For example, my Schwitzer S1BG was originally used on some sort of a tractor. Can withstand continuous 30+ psi of boost and supports over 200 hp even though it's physically the same size as an OEM KKK K24.
Of course, spool-up will also have a great deal to do with what kind of an injection pump you are using. A well tuned pump can help you spool up a surprisingly big turbo, while with a stock pump you're looking at problems even with a moderately sized one.
Reply #22January 06, 2009, 01:39:54 pm
zaprzal
  • 160
    • turbodiesel.pl
« Reply #22 on: January 06, 2009, 01:39:54 pm »
Quote from: "TurboJ"
my holset hx27w was on grape harvester  :lol:
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #23January 06, 2009, 01:42:37 pm
TurboJ
  • 661
« Reply #23 on: January 06, 2009, 01:42:37 pm »
lol
No, really, the agricultural turbos are great. Nobody will doubt toughness of harvester parts  8)
Reply #24January 06, 2009, 03:43:04 pm
Jasonsmack
  • 21
« Reply #24 on: January 06, 2009, 03:43:04 pm »
I will probably stick with the stock AAZ pump. I will surely turn it up some but I am not really looking to find the limits on the settings. If I can squeeze 100-125 hp out of the engine and still have it drivable and dependable that would be great.
Reply #25January 06, 2009, 04:41:16 pm
TurboJ
  • 661
« Reply #25 on: January 06, 2009, 04:41:16 pm »
Quote from: NoSurrenderAG
where the hell do you look for a turbo like that lol.. I bet they're pretty cheap too
I did get a very good deal on mine. Just regular used tuning parts classifieds on my local forum. I just hope my turbo is as fresh as the selller told me. It's always exciting on a long project to see how everything works together once finally bolted on.
Try to search for an Offroad forum - there's bound to be many diesel engines around there so diesel-specific turbos for sale should be plentiful.
