Author Topic: AAZ oil pressure ??  (Read 4454 times)
July 03, 2008, 03:03:15 pm
stewardc
AAZ oil pressure ??
« on: July 03, 2008, 03:03:15 pm »
Now that I have an oil pressure gauge, what is normal for a good AAZ?
Reply #1July 04, 2008, 03:01:55 am
stewardc
AAZ oil pressure ??
« Reply #1 on: July 04, 2008, 03:01:55 am »
I'm getting 5-6 BAR cold reving it up and about 1.5-2 bar hot idle.
Reply #2July 08, 2008, 03:19:06 am
stewardc
AAZ oil pressure ??
« Reply #2 on: July 08, 2008, 03:19:06 am »
BUMP, anyone ????
Someone must have a gauge on a good AAZ ??
Reply #3July 08, 2008, 05:12:05 am
AAZ oil pressure ??
« Reply #3 on: July 08, 2008, 05:12:05 am »
Sounds similar to what mine is, maybe a little higher cold pressure. I was worried mine was a little low with the stories of 1.6's at 90 psi and such, but even with new bearings(minus intermediate shaft which were good) it still stays the same.
Reply #4July 08, 2008, 06:55:07 am
AAZ oil pressure ??
« Reply #4 on: July 08, 2008, 06:55:07 am »
We need to know:
- the measurement site
- oil rating and type
- oil temperature
to have a meaningful comparison.
Having said that, at the oil filter flange with 15W40 dino (ie break-in) oil at 100C my oil pressure gauge and my tach are aligned.. 1bar at idle, 2 bar at 2000 RPM, 3 bar at 3000 rpm etc.
Fresh engine with all new bearings, original oil pump that was well within Bentley wear specs.
Reply #5July 08, 2008, 10:08:44 am
bert
  • 423
AAZ oil pressure ??
« Reply #5 on: July 08, 2008, 10:08:44 am »
mines 5w40 syn oil, sender on head,i get 9 bar at the head cold tick over,drops to 2 bar tick over at 110 degrees oil temp revved up it goes to about 6 bar max when hot any rpm.
Bert
Reply #6July 08, 2008, 10:11:10 am
stewardc
AAZ oil pressure ??
« Reply #6 on: July 08, 2008, 10:11:10 am »
OK, it sounds about right then. I have the sender in the head (may move it to the filter flange) and 15-40 breakin oil.
Is there any easy way to get more hot oil pressure?
Reply #7July 08, 2008, 10:23:48 am
bert
  • 423
AAZ oil pressure ??
« Reply #7 on: July 08, 2008, 10:23:48 am »
put the tickover up  :wink:
Bert
Reply #8July 08, 2008, 11:04:44 am
stewardc
AAZ oil pressure ??
« Reply #8 on: July 08, 2008, 11:04:44 am »
Quote from: "bert"
Bert
 :lol: nyuk, nyuk, nyuk
Reply #9July 13, 2008, 05:44:02 am
mdonau
  • 53
AAZ oil pressure ??
« Reply #9 on: July 13, 2008, 05:44:02 am »
2 [email protected] to data in ESI-Tronic
thats also what my "aaz" has with 5w40 HC, soon i will switch to mobil1 5w50...my engine ist a little "hottie"  :roll:
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
