AAZ oil pressure ??
Topic: AAZ oil pressure ?? (Read 4537 times)
July 03, 2008, 03:03:15 pm
stewardc
AAZ oil pressure ??
July 03, 2008, 03:03:15 pm »
Now that I have an oil pressure gauge, what is normal for a good AAZ?
July 04, 2008, 03:01:55 am
stewardc
AAZ oil pressure ??
July 04, 2008, 03:01:55 am »
I'm getting 5-6 BAR cold reving it up and about 1.5-2 bar hot idle.
July 08, 2008, 03:19:06 am
stewardc
AAZ oil pressure ??
July 08, 2008, 03:19:06 am »
BUMP, anyone
Someone must have a gauge on a good AAZ ??
July 08, 2008, 05:12:05 am
AAZ oil pressure ??
July 08, 2008, 05:12:05 am »
Sounds similar to what mine is, maybe a little higher cold pressure. I was worried mine was a little low with the stories of 1.6's at 90 psi and such, but even with new bearings(minus intermediate shaft which were good) it still stays the same.
July 08, 2008, 06:55:07 am
AAZ oil pressure ??
July 08, 2008, 06:55:07 am »
We need to know:
- the measurement site
- oil rating and type
- oil temperature
to have a meaningful comparison.
Having said that, at the oil filter flange with 15W40 dino (ie break-in) oil at 100C my oil pressure gauge and my tach are aligned.. 1bar at idle, 2 bar at 2000 RPM, 3 bar at 3000 rpm etc.
Fresh engine with all new bearings, original oil pump that was well within Bentley wear specs.
July 08, 2008, 10:08:44 am
bert
AAZ oil pressure ??
July 08, 2008, 10:08:44 am »
mines 5w40 syn oil, sender on head,i get 9 bar at the head cold tick over,drops to 2 bar tick over at 110 degrees oil temp revved up it goes to about 6 bar max when hot any rpm.
Bert
July 08, 2008, 10:11:10 am
stewardc
AAZ oil pressure ??
July 08, 2008, 10:11:10 am »
OK, it sounds about right then. I have the sender in the head (may move it to the filter flange) and 15-40 breakin oil.
Is there any easy way to get more hot oil pressure?
July 08, 2008, 10:23:48 am
bert
AAZ oil pressure ??
July 08, 2008, 10:23:48 am »
put the tickover up :wink:
Bert
July 08, 2008, 11:04:44 am
stewardc
AAZ oil pressure ??
July 08, 2008, 11:04:44 am »
Quote from: "bert"
Bert
:lol: nyuk, nyuk, nyuk
July 13, 2008, 05:44:02 am
mdonau
AAZ oil pressure ??
July 13, 2008, 05:44:02 am »
[email protected]
to data in ESI-Tronic
thats also what my "aaz" has with 5w40 HC, soon i will switch to mobil1 5w50...my engine ist a little "hottie" :roll:
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
AAZ oil pressure ??
