Author Topic: retrofit Oil Pan Gasket with Baffle? Do I need one?  (Read 2758 times)
March 27, 2008, 07:18:24 am
Ziptar
  • 565
« on: March 27, 2008, 07:18:24 am »
I was putting togetehr a list of parts I need on Autohaus Az's website and pulled up a pan gasket and they list two.
Part# 044103609D "Oil Pan Gasket; Reinforced Rubber" $13.56
Part# 037115220B " Oil Pan Gasket; With Baffle,  Update retrofit with baffle plate to prevent oil pump starvation under severe conditions."  $36.24
That is first I have seen of one with a baffle. I can see the point I guess, seems like a way to go. just not sure, any cons to using the upgraded one?
Thanks,
Reply #1March 27, 2008, 07:40:52 am
« Reply #1 on: March 27, 2008, 07:40:52 am »
My AAZ came stock with one. Since it's bonded to the baffle, it can't slip out of place either. You should get it.
Reply #2March 27, 2008, 08:42:29 am
« Reply #2 on: March 27, 2008, 08:42:29 am »
yeah pretty much all engines after 93 made by VW had them. Not sure about the CLs though. I had one on my 1.6TD.
Reply #3March 27, 2008, 10:17:17 am
Ziptar
  • 565
« Reply #3 on: March 27, 2008, 10:17:17 am »
OK, Added to teh list. Thanks.
