Author Topic: IDI to DI Power Potential  (Read 23008 times)
Reply #15January 15, 2008, 11:32:56 am
Öl-Brenner
  • 11
« Reply #15 on: January 15, 2008, 11:32:56 am »
I dug up the following info regarding the 1.2 and 1.4 TDI from the A2.  There are both 1.2L and 1.4L 3 cylinder diesel that were used in the A2.  The 1.2L Engine code "ANY" uses 76.5mm pistons with 24mm wristpin and is direct injection with 61 HP, Engine code "AMF,BHC,ATL" are 1.4L Direct injected with 79.5 mm pistons with 26mm wristpin.  AMF & BHC=75 HP, ATL= 90 HP.  There are different part numbers for the connecting rods between 1.2 and 1.4 versions.  Also all versions are PD injection with Turbocharging and intercooling.
Best Regards,
Noel
Impossible? Never!
'82 Vanagon Diesel 5cyl TD conv in '98
'86 Vanagon Syncro (soon to be TD)
'74 Merc 250/8 gasser CKD Japan
'86 Golf (Daily Driver)
Reply #16January 15, 2008, 12:03:07 pm
Helliouse
  • 164
« Reply #16 on: January 15, 2008, 12:03:07 pm »
Well well i have found the complete piston stats for the 1.2l TDI
Now does any one have the stats for the 1.6l?
Might be in the shop manual...will check that when i get home.
Piston:
Piston Out Dia. Φ 76.465
Measured: Φ 76.463
Overall Length 63.05
Measured: 63.07
Compression Height 41.865
Measured: 41.866
Ring Groove Width Top 1.841
Measured: 1.842
2nd 2.048
Measured: 2.047
3rd 3.029
Measured: 3.032
Pin Hole Dia. 24.012
Measured: 24.011
Offset 0.48
Measured: 0.47
Land Thickness Top 8.95
Measured: 8.94
2nd 5.0
Measured: 5.0
3rd 2.79
Measured: 2.79
Crown Thickness 8.55
Measured: 8.63
Boss Distance
Weight (g) 469.8 g
Measured: 470.4 g
Found here is a PDF
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #17January 15, 2008, 12:22:20 pm
rallydiesel
  • 1880
« Reply #17 on: January 15, 2008, 12:22:20 pm »
The wheels are turning.  :twisted:
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #18January 15, 2008, 12:53:40 pm
haybayian
  • 155
« Reply #18 on: January 15, 2008, 12:53:40 pm »
Quote from: "MJF"
Quote from: "haybayian"
Shorter connecting rods  and lighter pistons means less moving weight and higher rpm. The cost of course is lower compression (which I addressed in my post). :)
Shorter rod in not always lighter. I have 20mm longer rods than stock and itīs still lighter than stock. And shorter rod will always be worse than longer (rod/stroke ratio)
I think you are missing my point. A shorter stroke always yields higher rpm  in any IC engine, in most cases producing higher HP  at the cost of low end torque.  It all depends what you want to achieve . My argument is that a VW 1.9 L TD diesel could produce more than 100 hp/litre if it was given an opportunity to rev higher.
Keep it simple if you can.
Reply #19January 15, 2008, 03:07:31 pm
MJF
  • 581
« Reply #19 on: January 15, 2008, 03:07:31 pm »
Quote from: "MJF"
So you want shorter stroke? Or rods? Two different things. 128hp/litre at the moment from destroked 1,9 bottom...
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #20January 15, 2008, 06:01:05 pm
haybayian
  • 155
« Reply #20 on: January 15, 2008, 06:01:05 pm »
[Quote
So you want shorter stroke? Or rods? Two different things. 128hp/litre at the moment from destroked 1,9 bottom...[/quote]
I want shorter stroke and I believe that shorter rods is simpler and less expensive than a re-engineered crankshaft (am I wrong?)
It would be useful if you could elaborate on the 128 hp/litre engine you are refering to. What was done to it, actually?
Reply #21January 15, 2008, 07:22:47 pm
« Reply #21 on: January 15, 2008, 07:22:47 pm »
[Quote
It would be useful if you could elaborate on the 128 hp/litre engine you are refering to. What was done to it, actually?[/quote]
that is his 1.7L monster... he somehow finnished the motor and extracted 200+hp!!!  :lol:
Reply #22January 15, 2008, 09:49:34 pm
« Reply #22 on: January 15, 2008, 09:49:34 pm »
[Quote
Shorter rods will only get you lower compression. You HAVE to mess with the crank to get a shorter stroke, then you have to get rods or a piston/rod combo that matches the changed stroke.
Reply #23January 16, 2008, 05:05:55 am
moTthediesel
  • 194
« Reply #23 on: January 16, 2008, 05:05:55 am »
Stroke is a function of the crank throw eccentric (the distance from main bearing axis to rod bearing axis X 2). Changing the rod length will affect compression ratio and valve interference, but will not alter the stroke.
In other words, rod length controls where in the cylinder the piston goes up and down, but only the crank controls how far up and down the piston goes.
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #24January 16, 2008, 06:00:07 am
haybayian
  • 155
« Reply #24 on: January 16, 2008, 06:00:07 am »
Quote from: "moTthediesel"
moT
Thanks you guys, indeed stroke is a function of crank rotation.
I stand corrected.
My question remains: what is the best way to increase  maximum rpm?
Reply #25January 16, 2008, 06:55:53 am
« Reply #25 on: January 16, 2008, 06:55:53 am »
Buy a gas engine. Diesels have more forces and pressures. The components are heavier. You aren't going to get the same rpm's out of a Diesel. Lower compression some, increase boost, increase torque. That's what it's all about, the wide range of pulling power so that you don't have to stay in some narrow high rpm powerband.
Reply #26January 16, 2008, 07:36:29 am
MJF
  • 581
« Reply #26 on: January 16, 2008, 07:36:29 am »
I donīt understand why you all want to lower your compression. I have 24+CR and works fine with 35psi boost. It also revs very happily to 5800rpm, more higher next summer...
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #27January 16, 2008, 08:48:58 am
914turboford
« Reply #27 on: January 16, 2008, 08:48:58 am »
I'm sorry for the dumb question but why can't you run 1.6 IDI turbo pistons with a DI head? If there is something about the crown shape that is undesirable can you machine them?
Reply #28January 16, 2008, 08:49:27 am
haybayian
  • 155
« Reply #28 on: January 16, 2008, 08:49:27 am »
Quote from: "MJF"
It looks that I have yet to learn quite a bit about performance in diesels. I would like to know what you have done to your engine for it to rev happily to 5800 rpm. My stock AAZ is rated 75 hp @ 4500 rpm. I had my VE IP rebuilt with performance mods by a guy called Giles in Toronto. I have a Garrett T3, rebuilt too. I will run 25-30 psi of boost. My intercooler is from a TDI. I have made a 3" exhaust system. If you have time please tell me what I should do to get this engine to crank out 200 bhp.
Thanks.
Haybayian
Reply #29January 16, 2008, 09:11:23 am
« Reply #29 on: January 16, 2008, 09:11:23 am »
Quote from: "914turboford"
IDI pistons
DI pistons
Your CR would be through the roof and there would be poor air turbulence
