There are some non-VW IDIs that make a lot of power.. particularly the inline-5 3.0L MB engines.Cheers,Mark
I would like to rebuild (one day) a AAZ with shorter connecting rods and lighter pistons. This along with other blueprinting measures would allow this engine to rev higher (maybe 6500 rpm).
Thank you Mark for this outstanding contribution.I am like you, I hope and believe that IDIs have a future and that the advent of DIs, single rail HDi, etc is not signalling the end of an era for mechanical injection diesels but rather a plateau.I find your comments (and your source's) concerning the need to redesign prechambers very interesting but as a newbie , a user, (and crude amateur) I can only say: please go for it.Here are my own thoughts about TD performance(please don't laugh).Apart from what you are suggesting regarding fuel atomization (heat), I would like to suggest that one way to make IDIs more performing would be to reduce the compression ratio down to 14-1. The pressure inside the combustion chamber would drop of course to perhaps 160 psi (just a guess). An external compressor (positive displacement) driven by the AAZ crank would provide an additional 175 psi and feed the the cylinders via an air tank.I would like to rebuild (one day) a AAZ with shorter connecting rods and lighter pistons. This along with other blueprinting measures would allow this engine to rev higher (maybe 6500 rpm). Just food for thought. I hope I will not bore anyone.Haybayian.
1,2TDI has 24mm piston pin. Dunno how long rod it has. Quote from: "haybayian"I would like to rebuild (one day) a AAZ with shorter connecting rods and lighter pistons. This along with other blueprinting measures would allow this engine to rev higher (maybe 6500 rpm). Why shorter :shock: The longer the better. 1Y already have longer rods (150mm) and lighter pistons :wink:
Shorter connecting rods and lighter pistons means less moving weight and higher rpm. The cost of course is lower compression (which I addressed in my post).
