Author Topic: best turbo  (Read 18877 times)
December 12, 2007, 03:24:56 am
dillenger1
  • 777
best turbo
« on: December 12, 2007, 03:24:56 am »
whats the next bumpm in power from a k14?Ive been doing some searches and it seems like im going to be limited to grunty low end power.i was womdering if theres a solution without going to vnt's
ben
 p.s. ive not even assembled the motor(1.6ltr na)ill be buying parts soon
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1December 12, 2007, 03:55:54 am
Ziptar
  • 565
best turbo
« Reply #1 on: December 12, 2007, 03:55:54 am »
Best turbo depends on what you want to accomplish.
For quick spool up you'd want a K14, for max boost a K03, there is also the K24 which I think is sort of between the two.
The K14 spools quick but is limited to 18-20 lbs of boost, a K03 will take lots of boost but spool up ~1,000 RPM later.
VNT on an IDI has been done by several, search for it. There is also a thread on Jack's forum http://vwdiesel.net/phpBB/viewtopic.php?t=8065
Reply #2December 12, 2007, 04:55:05 am
haybayian
  • 155
best turbo
« Reply #2 on: December 12, 2007, 04:55:05 am »
Quote from: "Ziptar"
Hi,
Could some one offer guidance I don't know what my turbo is. I can read Garrett.  BCC. F4 on it and I was told by the shop that is came from a 1.6 VW. Thanks.
Haybayian
Keep it simple if you can.
Reply #3December 12, 2007, 04:57:14 am
best turbo
« Reply #3 on: December 12, 2007, 04:57:14 am »
Probably a T3 haybayian.
I want to buy a K14 if someone is selling 8)
Reply #4December 12, 2007, 05:02:26 am
DooeyTrials
  • 13
best turbo
« Reply #4 on: December 12, 2007, 05:02:26 am »
I think i have a K14 but i am not sure as i am not able to see any labels on the turbo?
i will have a closer look when taking the head off ready for the new one.
if it is a k14 is it ok to up the boost a bit?
Chris
Reply #5December 12, 2007, 05:06:16 am
haybayian
  • 155
best turbo
« Reply #5 on: December 12, 2007, 05:06:16 am »
Quote from: "burn_your_money"
Thanks BYM
What are the T3 performance characteristics?
Haybayian
Reply #6December 12, 2007, 05:14:34 am
best turbo
« Reply #6 on: December 12, 2007, 05:14:34 am »
I find T3s big and laggy with stock fueling and a stock exhaust but as I've found out mine was rather worn so that may not be accurate
Reply #7December 12, 2007, 07:08:14 am
spencebm
  • 686
best turbo
« Reply #7 on: December 12, 2007, 07:08:14 am »
i run a k14 off an ecodiesel and it is great man.  i run almost 19 lbs boost and it is spooled all the time.  im getting a turbo pump on there soon and i dont think you would want to run much more boost than that with proper fueling.  go with the k14!
Ben Spencer
Reply #8December 12, 2007, 10:13:40 am
dillenger1
  • 777
best turbo
« Reply #8 on: December 12, 2007, 10:13:40 am »
fueling shouldnt be a problem, Now ,do i want a k14 from a vw ?There are different versions of the k14 right?External or internal waiste gate?Can you keep an internal wg closed longer mechanically?
ben
Reply #9December 12, 2007, 12:59:27 pm
best turbo
« Reply #9 on: December 12, 2007, 12:59:27 pm »
i thought it went K03, K14, then K24? and garrett (which most believe is superior) T2, and T3.
Reply #10December 12, 2007, 01:28:17 pm
best turbo
« Reply #10 on: December 12, 2007, 01:28:17 pm »
There are a lot of different K03s, I believe the diesel one is a K03 003
Reply #11December 12, 2007, 04:36:03 pm
bevboyy
  • 200
best turbo
« Reply #11 on: December 12, 2007, 04:36:03 pm »
T2 gets my bill. Good overall boost down low. Good for 17 psi.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #12December 12, 2007, 04:41:36 pm
best turbo
« Reply #12 on: December 12, 2007, 04:41:36 pm »
Nope, they're just big and laggy with stock fuel and exhaust !
Reply #13December 12, 2007, 05:05:48 pm
Ziptar
  • 565
best turbo
« Reply #13 on: December 12, 2007, 05:05:48 pm »
Quote from: "jtanguay"
You are probably right, I can't keep them straight.  :wink:
Reply #14December 12, 2007, 06:55:52 pm
best turbo
« Reply #14 on: December 12, 2007, 06:55:52 pm »
i like the internal wastegates better for simpler plumbing... but the external flows alot better and will give you more power once you reach max boost.
