Psi is really relitive and what we need to be more concerned with is volume.
First thing to address if you are running a stock ko3 / k14 / t2, the most it will do is about 18psi after that it is just hot air, and your drive pressures are through the roof! and Egt's get outta control quickly.
If you are running a k24 / t3 off of a 1.6TD then you have to about 24psi after which you don't gain much either.
I personally have run on a 1.6TD with the stock pump at its ragged edge borderline runaway for fueling and 35+ psi, and probably closer to 40psi, I had a boost controller malfunction going up to the tollbooth on the way from vancouver to kamloops, on the 10% grade. Anyone from the area will know what I'm talking about just after you go through the snow shed. I had my foot to the floor, and the controler failed my wastegate was fully closed and it wrapped my 35psi autometer gauge. This was on stock head bolts, stock fiber gasget, and it lived.
That same car went through 3 or 4 020 transmissions and saw 28-30psi everyday for 8months without a single motor problem and was beat! Many runs in excess of 180km/h and pyro temps in the 1800F range.
I personally know several other people with cars running 24+psi out of stock k24 or t3's and never having problems, intercooled or not, as the volume of air just isn't there.
The headgasget problems I have seen to date are caused by three things:
-Head or motor resurfaced and not done to spec. Ie: head not perfectly flat.
-Overheating the motor! this is the leading cause! watch those engine temps, even closer then the pyro!
-Too much volume with the boost
Now we all know or should know that your 29psi, is not Andy's 29psi.
Just as I will put this in Cummins terms as your are probably most familiar with that 29psi out of a HX-35 is not equal to 29psi out of a Sledpuller 66, or in duramax terms 29psi out of the stock IHI is not the same as 29psi out of an Aurora 5000.
So what are the exact limits of the gasket, I don't know, but I do know this. Twin turbo's like Andy's are too much, and so is a GT20 at 30+psi, but a stock you can run as much as the turbo will let you and you should be okay.
The one thing I know forsure is the next motor I build will have the head and the block O-ringed.
