I'm in the process of buying/shipping an '03 Passat ALH engine that the previous owner bought, swapped to a mechanical pump and different turbo, ran very briefly in a jet boat, and then gave up on figuring out why it didn't have enough power, and swapped for a bigger gasser.
195,000 miles, and a supposedly a Land Rover 300TDI used pump that was rebuilt, as well as, in his words "I have the stock turbo manifold and a cast iron manifold that has a T3 mount and a new GT2052 turbo." He also has some other parts that came with it that he did not use in the boat installation. Coolant piping was modified for the boat, so I'll need to source a new one of those, vacuum pump removed, and other unneeded accessories removed.
The guy knows less about wrenching on and tuning diesels than I do, so who knows where this went wrong, but he put the engine in a jet boat, and said that it seemed really down on power, and acted as if (from his gauge of experience) that with the propeller setup he had on it, that it only must have had about 80hp, and that was at 2100rpm which was the maximum he could get it to rev at full throttle.
What possible suspects should be looked at first here?
I'm not sure what rpm's that turbo spools up and reaches good boost levels at, but perhaps it is too big of a turbo for the application he was using it for, and the thing was never able to spool up? I had read a lot of good things about the GT2052, but still not enough specific for my desires of finding out if it will spool up fairly quickly with minimal lag, and what kind of boost it is good for, and longevity.
I also thought perhaps he has the timing set way off, but he said he followed procedures outlined on a VW diesel website pretty exactly on how to time it.
Injectors are the originals in unknown condition.
Could also be that maybe the fuel screw was far too lean? Or some problem internal to the pump that was hurting fueling?
For $1200 + freight, I feel like I can't really go too wrong here with a pricey newer turbo and a Land Rover 300TDI(?) mechanical Bosch VE injection pump, as it was running at least, and is said to have 195,000 miles. Not bad at all for an ALH, they seem to last forever, so Libby and many others have said. As in "much better metallurgy, to the point that a 200,000 mile teardown shows practically no detectable cylinder bore wear." At any rate, I'd like to know what I'm getting into here, and where the problems could lie.
Something wrong inside the pump, post-rebuild (done at a shop in Oregon supposedly)?
Just simply not enough fuel?
Turbo too big to make power down low, and it never was able to spool up in his test run?
Injection timing way off?
Cam timing off?
Injector issues?
Governor issues on pump? I had read that the 300TDI Rover pump needs the governor modded or else it will not rev out, but I would think it would rev higher than 2100rpm under heavy load at least! I had read that the 200TDI pump revs higher and does not have a restrictive governor.
The numbers on the Land Rover injection pump are:
ERR 6700, 0 460 414 136
He said it bolts right on and the stock pulley/sprocket fit it perfectly.
Can anyone decode anything of any noteworthiness from those numbers?
