| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 1 463 100 307 BEARING PIN 1463100307 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 315 ADJUSTING PIN 1463103315 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 469 TIMING-DEVICE PISTON 1463104469 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 100 902 SELECTION GROUP SHIM RING 1460100902 33 2 1 464 619 734 COMPRESSION SPRING, 36,30 MM 1464619734 34 1 1 464 619 628 COMPRESSION SPRING, 36,50 MM 1464619628 34 1 1 464 619 619 COMPRESSION SPRING, 36,70 MM 1464619619 34 1 1 460 100 902 SELECTION GROUP SHIM RING 1460100902 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 301 CLOSING COVER 1465530301 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 312 COVER PLATE 1461074312 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 2 1 468 334 487 HYDRAULIC HEAD 1468334487 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 FITTING 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 1 1 467 134 815 HYDRAULIC STOP 1467134815 67 1 1 463 161 835 PART LOAD GOVERNOR 1463161835 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 496 CONTROL LEVER 1461900496 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 810 FULCRUM LEVER 1461907810 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 305 SLIDING SLEEVE 1460422305 115 1 1 461 290 301 LOCKING PLATE 1461290301 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 419 CONTROL VALVE 1460362419 135 1 1 463 456 358 HOLLOW BOLT 1463456358 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 360 CONTROL UNIT 1467230360 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 309 COUPLING HALF 1466434309 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 514 CONTROL LEVER 1461900514 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 460 342 311 INTERMEDIATE PIECE 1460342311 295 1 1 463 412 301 CHEESE HEAD SCREW 1463412301 296 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 463 450 308 BREAK-OFF SCREW 1463450308 307 2 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 350 CONNECTING PIPE 1460793350 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 344 CONTROL LEVER 1461933344 382 1 1 461 933 341 CONTROL LEVER 1461933341 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 901 483 CONTROL LEVER 1461901483 388 1 1 460 300 318 SPACER BUSHING 1460300318 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 1 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 423 450 002 BREAK-OFF SCREW 2423450002 418 2 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 1 461 329 339 MOUNTING BRACKET 1461329339 492 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1 460 140 334 27 1 1 466 110 653 CAM PLATE 1466110653 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 997 HYDRAULIC STOP 1467135997 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 2 463 461 002 SCREW PLUG 2463461002 130 1 2 463 461 001 BLEEDER SCREW 2463461001 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 461 021 621 SUPPORT PLATE 1461021621 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 1 463 300 320 HEXAGON NUT 1463300320 422 1 SELECTION GROUP SHIM 452 3 1 464 616 340 COMPRESSION SPRING 1464616340 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 134 990 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134990 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 996 HYDRAULIC STOP 1467135996 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 461 021 621 SUPPORT PLATE 1461021621 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 903 310 CONTROL LEVER 1461903310 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 998 COMPRESSION SPRING 1464616998 453 1 1 464 616 955 COMPRESSION SPRING 1464616955 453 1 1 464 616 344 COMPRESSION SPRING 1464616344 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 134 990 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134990 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 653 CAM PLATE 1466110653 29 1 1 461 074 328 SEALING PLATE 1461074328 30 1 1 463 104 667 TIMING-DEVICE PISTON 1463104667 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 1 461 038 319 SEALING PLATE 1461038319 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 2 461 038 019 COVER PLATE 2461038019 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 4 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 361 MICROENCAPSULATED SCREW, MICO 1463414361 60 2 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 999 HYDRAULIC STOP 1467135999 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 F 002 D11 460 GOVERNOR SHAFT, MICO F002D11460 108 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 2 463 461 002 SCREW PLUG 2463461002 130 1 2 463 461 001 BLEEDER SCREW 2463461001 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 461 021 621 SUPPORT PLATE 1461021621 235 1 1 463 414 362 MICROENCAPSULATED SCREW, MICO 1463414362 237 2 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 041 PUSHING ELECTROMAGNET 0330001041 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 2 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 F 002 D11 455 HOLLOW BOLT, MICO F002D11455 353 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 F 002 D11 455 HOLLOW BOLT, MICO F002D11455 357 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 1 463 300 320 HEXAGON NUT 1463300320 422 1 SELECTION GROUP SHIM 452 3 1 464 616 340 COMPRESSION SPRING 1464616340 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 465 134 967 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134967 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 653 CAM PLATE 1466110653 29 1 1 461 074 328 SEALING PLATE 1461074328 30 1 1 463 104 667 TIMING-DEVICE PISTON 1463104667 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 1 461 038 319 SEALING PLATE 1461038319 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 2 461 038 019 COVER PLATE 2461038019 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 4 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 997 HYDRAULIC STOP 1467135997 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 2 463 461 002 SCREW PLUG 2463461002 130 1 2 463 461 001 BLEEDER SCREW 2463461001 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 0 281 005 025 SOLENOID-VALVE CONTROL UN 0281005025 184 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 460 COILED SPRING 1464651460 220 1 1 461 021 889 SUPPORT PLATE 1461021889 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 3 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 1 463 300 320 HEXAGON NUT 1463300320 422 1 SELECTION GROUP SHIM 452 3 1 464 616 340 COMPRESSION SPRING 1464616340 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 465 134 967 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134967 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 1 467 010 556 PARTS SET THEFT PROTECTION 1467010556 825 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1 460 140 334 27 1 1 466 110 639 CAM PLATE 1466110639 29 1 1 461 074 328 SEALING PLATE 1461074328 30 1 1 463 104 667 TIMING-DEVICE PISTON 1463104667 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 1 461 038 319 SEALING PLATE 1461038319 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 2 461 038 019 COVER PLATE 2461038019 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 4 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 996 HYDRAULIC STOP 1467135996 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 0 281 005 025 SOLENOID-VALVE CONTROL UN 0281005025 184 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 460 COILED SPRING 1464651460 220 1 1 461 021 889 SUPPORT PLATE 1461021889 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 3 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 903 310 CONTROL LEVER 1461903310 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 963 COMPRESSION SPRING 1464616963 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 465 134 967 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134967 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 1 467 010 556 PARTS SET THEFT PROTECTION 1467010556 825 1 |
| Mark Type Part number Applications Photo Engine bosch VE 0460404005 VE R 14/1 Ford Transit 100/190 46 kw York bosch VE 0460414073 VE R 366 Ford Transit 2.5D 52 kw 4 AB, 4 CA Enquiries bosch VE 0460414083 VE R 415 Ford Transit 2.5 DI 59 kw 4 DA bosch VE 0460414108 VE R 567 Ford Transit 2.5 D 56 kw 4 HA, 4 HB, 4 FA, 4 FC bosch VE 0460414113 VE R 567/1 Ford Transit 2.5 D 51 kw 4 FA, 4 FB, 4 FC bosch VE 0460414119 VE R 624 Ford Transit, Tourneo 51-56 kw 4 FB, 4HB, 4HC … bosch VE 0460414146 VE R 686/3 Ford Transit 2.5 D 56 kw 4 HB, 4 HC KAT bosch VE 0460414150 VE R 624/4 Ford Transit 2.5 D 56 kw 4 FA, 4 FB, 4 FC 4 HB, 4 HC |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 1 463 100 307 BEARING PIN 1463100307 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 315 ADJUSTING PIN 1463103315 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 469 TIMING-DEVICE PISTON 1463104469 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 100 902 SELECTION GROUP SHIM RING 1460100902 33 2 1 464 619 734 COMPRESSION SPRING, 36,30 MM 1464619734 34 1 1 464 619 628 COMPRESSION SPRING, 36,50 MM 1464619628 34 1 1 464 619 619 COMPRESSION SPRING, 36,70 MM 1464619619 34 1 1 460 100 902 SELECTION GROUP SHIM RING 1460100902 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 301 CLOSING COVER 1465530301 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 312 COVER PLATE 1461074312 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 2 1 468 334 487 HYDRAULIC HEAD 1468334487 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 FITTING 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 134 823 HYDRAULIC STOP 1467134823 67 1 1 463 162 063 PART LOAD GOVERNOR 1463162063 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 564 CONTROL LEVER 1461900564 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 810 FULCRUM LEVER 1461907810 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 305 SLIDING SLEEVE 1460422305 115 1 1 461 290 301 LOCKING PLATE 1461290301 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 419 CONTROL VALVE 1460362419 135 1 1 463 456 358 HOLLOW BOLT 1463456358 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 360 CONTROL UNIT 1467230360 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 309 COUPLING HALF 1466434309 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 566 CONTROL LEVER 1461900566 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 2 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 460 342 311 INTERMEDIATE PIECE 1460342311 295 1 1 463 412 301 CHEESE HEAD SCREW 1463412301 296 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 350 CONNECTING PIPE 1460793350 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 903 304 CONTROL LEVER 1461903304 388 1 1 460 200 339 SPACER RING 1460200339 389 2 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1 460 140 334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 580 HYDRAULIC HEAD 1468334580 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 134 842 HYDRAULIC STOP 1467134842 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 639 CONTROL LEVER 1461900639 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 808 FULCRUM LEVER 1461907808 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 360 CONTROL UNIT 1467230360 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 963 COMPRESSION SPRING 1464616963 453 1 1 464 616 956 COMPRESSION SPRING 1464616956 453 1 1 464 616 955 COMPRESSION SPRING 1464616955 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 653 CAM PLATE 1466110653 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 1 1 460 210 008 O-RING 1460210008 66 2 1 467 134 840 HYDRAULIC STOP 1467134840 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 639 CONTROL LEVER 1461900639 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 2 463 461 002 SCREW PLUG 2463461002 130 1 2 463 461 001 BLEEDER SCREW 2463461001 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 404 CONTROL UNIT 1467230404 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 3 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 300 312 SPACER BUSHING 1460300312 248 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 340 COMPRESSION SPRING 1464616340 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 460 591 318 HOOD 1460591318 720 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1 460 140 334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 1 1 460 210 008 O-RING 1460210008 66 2 1 467 134 843 HYDRAULIC STOP 1467134843 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 639 CONTROL LEVER 1461900639 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 404 CONTROL UNIT 1467230404 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 3 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 300 312 SPACER BUSHING 1460300312 248 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 903 310 CONTROL LEVER 1461903310 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 955 COMPRESSION SPRING 1464616955 453 1 1 464 616 344 COMPRESSION SPRING 1464616344 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 460 591 318 HOOD 1460591318 720 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 653 CAM PLATE 1466110653 29 1 1 461 074 328 SEALING PLATE 1461074328 30 1 1 463 104 667 TIMING-DEVICE PISTON 1463104667 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 1 461 038 319 SEALING PLATE 1461038319 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 2 461 038 019 COVER PLATE 2461038019 39 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 40 4 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 997 HYDRAULIC STOP 1467135997 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 F 002 D11 460 GOVERNOR SHAFT, MICO F002D11460 108 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 2 463 461 002 SCREW PLUG 2463461002 130 1 2 463 461 001 BLEEDER SCREW 2463461001 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 460 COILED SPRING 1464651460 220 1 1 461 021 621 SUPPORT PLATE 1461021621 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 F 002 D11 347 PUSHING ELECTROMAGNET F002D11347 240 1 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 F 002 D11 455 HOLLOW BOLT, MICO F002D11455 353 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 F 002 D11 455 HOLLOW BOLT, MICO F002D11455 357 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 1 463 300 320 HEXAGON NUT 1463300320 422 1 SELECTION GROUP SHIM 452 3 1 464 616 340 COMPRESSION SPRING 1464616340 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 465 134 967 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134967 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 337 CROSS DISK 1460140337 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 580 HYDRAULIC HEAD 1468334580 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 134 842 HYDRAULIC STOP 1467134842 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 808 FULCRUM LEVER 1461907808 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 460 COILED SPRING 1464651460 220 1 1 467 230 360 CONTROL UNIT 1467230360 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 335 348 CONTROL LEVER 1461335348 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 963 COMPRESSION SPRING 1464616963 453 1 1 464 616 956 COMPRESSION SPRING 1464616956 453 1 1 464 616 955 COMPRESSION SPRING 1464616955 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 1 463 126 333 SPHERICAL BOLT 1463126333 500 1 1 463 314 309 FLANGE NUT 1463314309 503 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 580 HYDRAULIC HEAD 1468334580 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 134 835 HYDRAULIC STOP 1467134835 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 639 CONTROL LEVER 1461900639 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 808 FULCRUM LEVER 1461907808 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 360 CONTROL UNIT 1467230360 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 903 310 CONTROL LEVER 1461903310 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 963 COMPRESSION SPRING 1464616963 453 1 1 464 616 956 COMPRESSION SPRING 1464616956 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 327 ROLLER RING 1460232327 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1 460 140 334 27 1 1 466 110 619 CAM PLATE 1466110619 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 580 HYDRAULIC HEAD 1468334580 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 134 830 HYDRAULIC STOP 1467134830 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 808 FULCRUM LEVER 1461907808 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 301 DISTANCE PIECE 1461314301 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 467 230 360 CONTROL UNIT 1467230360 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 0 330 001 040 PUSHING ELECTROMAGNET 0330001040 240 1 1 464 477 302 BLADE TERMINAL 1464477302 242 1 1 463 314 306 FLANGE NUT 1463314306 243 1 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 2 1 466 434 324 COUPLING HALF 1466434324 270 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 275 1 2 910 142 195 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x14-8.8 2910142195 276 2 2 460 223 001 SEAL RING 2460223001 277 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 310 WASHER-AND-SCREW ASSEMBLY 1463433310 292 1 1 463 218 303 INTERMEDIATE PIECE 1463218303 294 1 1 463 305 305 CLAMPING PIECE 1463305305 297 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 460 101 620 SHIM 1460101620 380 1 1 465 530 857 FITTING COVER 1465530857 381 1 1 461 933 363 CONTROL LEVER 1461933363 382 1 1 461 933 362 CONTROL LEVER 1461933362 382 1 1 461 331 331 STOP BRACKET 1461331331 383 1 1 464 651 433 COILED SPRING 1464651433 384 1 2 916 699 132 SPRING LOCK WASHER, DIN 128 - A6-FSt 2916699132 385 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 386 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 334 COMPRESSION SPRING 1464616334 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 1 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 130 862 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465130862 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 |
REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 653 CAM PLATE 1466110653 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 997 HYDRAULIC STOP 1467135997 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 2 463 461 002 SCREW PLUG 2463461002 130 1 2 463 461 001 BLEEDER SCREW 2463461001 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 0 281 005 025 SOLENOID-VALVE CONTROL UN 0281005025 184 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 461 021 889 SUPPORT PLATE 1461021889 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 3 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 335 346 CONTROL LEVER 1461335346 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 1 463 300 320 HEXAGON NUT 1463300320 422 1 SELECTION GROUP SHIM 452 3 1 464 616 340 COMPRESSION SPRING 1464616340 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 134 990 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134990 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 1 467 010 556 PARTS SET THEFT PROTECTION 1467010556 825 1 |
| REPLACING PARTS: ORDER NUMBER DESIGNATION CODE POSITION QUANTITY 2 460 283 001 SHAFT SEALING RING 2460283001 3 1 1 467 030 308 SUPPLY PUMP 1467030308 7 1 1 467 030 303 SUPPLY PUMP 1467030303 7 1 1 460 134 317 SUPPORT RING 1460134317 9 1 1 463 429 300 TORX FLAT-HEAD SCREW 1463429300 10 2 1 466 100 390 DRIVE SHAFT 1466100390 12 1 1 460 023 302 WOODRUFF KEY 1460023302 13 1 1 460 056 302 BUFFER 1460056302 15 2 1 466 317 301 TOOTHED GEAR 1466317301 16 1 2 460 102 001 SLIDING DISK 2460102001 17 1 1 460 232 328 ROLLER RING 1460232328 20 1 2 463 100 002 BEARING PIN 2463100002 21 4 2 460 300 005 ROLLER 2460300005 22 4 2 460 120 013 FRICTION WASHER 2460120013 23 4 1 463 103 316 ADJUSTING PIN 1463103316 24 1 1 463 120 359 RETAINING PIN 1463120359 25 1 1 461 310 300 RETAINING BRACKET 1461310300 26 1 1 460 140 334 CROSS DISK 1460140334 27 1 1 466 110 639 CAM PLATE 1466110639 29 1 2 460 223 001 SEAL RING 2460223001 30 1 1 463 104 508 TIMING-DEVICE PISTON 1463104508 31 1 1 463 218 312 SLIDING PIECE 1463218312 32 1 1 460 144 302 SHIM RING 1460144302 33 1 1 464 618 934 COMPRESSION SPRING 1464618934 34 1 1 460 100 178 PLAIN WASHER 1460100178 35 1 2 460 223 001 SEAL RING 2460223001 36 1 1 465 530 901 CLOSING COVER 1465530901 37 1 1 463 414 344 TORX FILLISTER SCREW 1463414344 38 2 1 461 074 330 COVER PLATE 1461074330 39 1 2 463 414 001 TORX FILLISTER SCREW 2463414001 40 2 1 468 334 859 HYDRAULIC HEAD 1468334859 50 1 2 460 210 012 O-RING 2460210012 51 1 SELECTION GROUP SHIM 52 1 1 460 105 305 GASKET 1460105305 54 4 2 463 370 021 FITTING 2463370021 58 4 1 463 414 312 TORX FILLISTER SCREW 1463414312 60 2 1 460 210 008 O-RING 1460210008 66 2 1 467 135 996 HYDRAULIC STOP 1467135996 67 1 1 463 162 081 PART LOAD GOVERNOR 1463162081 68 1 1 200 101 640 SHIM 1200101640 69 1 1 461 900 613 CONTROL LEVER 1461900613 72 1 1 463 315 310 FLANGE NUT 1463315310 75 1 ADJUSTING SCREW 88 1 1 461 015 302 GASKET 1461015302 92 1 1 461 907 803 FULCRUM LEVER 1461907803 95 1 2 916 012 017 PLAIN WASHER, DIN 433 - 10,5-160 HV 2916012017 103 1 1 463 452 313 SLOTTED SHOULDER SCREW 1463452313 104 2 1 460 105 307 GASKET 1460105307 105 2 1 464 613 611 COMPRESSION SPRING 1464613611 106 2 1 463 300 304 HEXAGON NUT 1463300304 107 1 1 463 590 311 GOVERNOR SHAFT 1463590311 108 1 1 460 210 313 O-RING 1460210313 109 1 1 461 030 343 SHIM PLATE, 0,95 MM 1461030343 110 1 SELECTION GROUP SUPPORTING DISK 111 1 1 466 317 319 FLYWEIGHT ASSEMBLY 1466317319 112 1 1 460 100 370 SHIM RING 1460100370 114 1 1 460 422 324 SLIDING SLEEVE 1460422324 115 1 1 460 508 309 SEALING CAP 1460508309 116 1 1 463 203 907 SELECTION GROUP PLUG 1463203907 117 1 2 910 142 207 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x35-8.8 2910142207 123 4 1 460 210 349 O-RING 1460210349 129 1 1 463 461 306 SCREW PLUG 1463461306 130 1 1 460 105 306 FLAT SEAL RING 1460105306 131 1 1 463 453 306 BLEEDER SCREW 1463453306 132 1 1 460 225 081 O-RING 1460225081 133 1 1 460 225 082 O-RING 1460225082 134 1 1 460 362 456 CONTROL VALVE 1460362456 135 1 1 463 456 360 HOLLOW BOLT 1463456360 136 1 1 460 591 315 PROTECTIVE CAP 1460591315 140 1 2 410 508 006 PROTECTIVE CAP 2410508006 141 1 0 281 005 025 SOLENOID-VALVE CONTROL UN 0281005025 184 1 2 464 633 002 COMPRESSION SPRING 2464633002 200 1 1 461 314 322 DISTANCE PIECE 1461314322 202 1 1 463 300 316 HEXAGON NUT 1463300316 206 1 2 916 699 137 SPRING LOCK WASHER, DIN 128 - A14-FSt 2916699137 207 1 1 464 651 452 COILED SPRING 1464651452 220 1 1 461 021 889 SUPPORT PLATE 1461021889 235 1 1 463 414 305 TORX FILLISTER SCREW 1463414305 237 2 1 460 105 312 FLAT SEAL RING 1460105312 251 1 2 910 142 203 HEX-SOCKET-HEAD CAP SCREW, ISO 4762 - M6x25-8.8 2910142203 254 3 1 466 434 324 COUPLING HALF 1466434324 270 1 2 410 508 006 PROTECTIVE CAP 2410508006 285 1 1 461 900 616 CONTROL LEVER 1461900616 289 1 1 461 900 615 CONTROL LEVER 1461900615 289 1 1 463 433 313 WASHER-AND-SCREW ASSEMBLY 1463433313 292 1 1 460 522 328 SPRING SEAT 1460522328 325 1 1 460 522 304 SPRING SEAT 1460522304 329 1 1 460 100 893 PLAIN WASHER 1460100893 346 1 2 911 222 700 HOLLOW BOLT 2911222700 353 1 2 911 222 700 HOLLOW BOLT 2911222700 357 1 1 460 105 313 FLAT SEAL RING 1460105313 358 2 1 460 105 313 FLAT SEAL RING 1460105313 364 2 1 460 793 379 CONNECTING PIPE 1460793379 365 1 1 461 903 310 CONTROL LEVER 1461903310 388 1 1 460 100 199 SPACER RING 1460100199 389 1 2 912 732 197 WASHER-AND-SCREW ASSEMBLY 2912732197 391 2 1 460 210 322 O-RING 1460210322 392 1 1 463 414 306 LOCKING SCREW 1463414306 393 1 1 461 331 325 INTERMEDIATE PLATE 1461331325 394 1 2 915 012 007 HEXAGON NUT, ISO 4032 - M6-8-A 2915012007 422 1 SELECTION GROUP SHIM 452 3 1 464 616 955 COMPRESSION SPRING 1464616955 453 1 1 464 616 344 COMPRESSION SPRING 1464616344 453 1 1 463 219 304 CONTROL SPOOL 1463219304 455 1 1 460 505 308 CLOSURE CAP 1460505308 471 1 1 463 126 333 SPHERICAL BOLT 1463126333 496 1 1 463 314 309 FLANGE NUT 1463314309 499 1 2 916 012 013 PLAIN WASHER, DIN 433 - 6,4-160 HV 2916012013 546 1 1 463 315 307 HEXAGON NUT 1463315307 580 2 1 467 010 062 PARTS SET COVER PLATE 1467010062 700 1 1 465 134 990 ASSEMBLY OF SERVICE PARTS PUMP HOUSING 1465134990 800 1 1 467 010 054 PARTS SET FLYWEIGHT 1467010054 805 1 1 460 591 313 SEALING CAP, RED 1460591313 808 1 2 420 580 005 SEALING CAP, RED 2420580005 809 1 1 467 010 556 PARTS SET THEFT PROTECTION 1467010556 825 1 |
