6.9l idi ford DB2 IP issue
by
wdkingery
on 07 Jul, 2013 13:37
My brother has a 1986 Ford f250 with a 6.9l idi IH motor in it. the previous owner installed a banks turbo, some gauges and a shift kit in the auto trans.
my brother dislikes driving and owning it, but I won't let him get rid of it, so it just sits.
well i have been out of the country as of late, and now that i'm back, i decided to fire it up and take it for a spin. boy i loved how it cranked right up after 6+ months of sitting!
well, drove it for about 20 minutes, was idling past the front door of a walmart and it just shut off. i mean plain conked out. this truck has never done this before! no, i don't abuse this one with motor oils, etc.
well, the only way it would fire up is if i gave it some skinny pedal. so i got it running, and now it idles on it's own, starts fine, etc. but something is wrong. it's like the gas pedal wont' push far enough; i cannot get boost to build very well, it won't stretch it's shifts on out like it should when floored.. but i checked the accelerator cable it's fine.
wonder what happened to that pump?? i suspected water in the fuel.. i've since checked the fuel i found in the filter, didn't find water.. added some iso-heet to the tanks.
anyone got an idea about why it just won't go? you almost have to floor it to accelerate normally, and this truck, with it's aftermarket turbo and IP turned all the way up used to zip right along 20 seconds before the walmart fall out.
i don't know enough about the 2 vacuum lines and the electrical bits on the IP.
#1
by
on 07 Jul, 2013 16:49
A clogged fuel filter would definitely do that. I'd start with a fresh filter and go from there.
Sent from my HTC One X using Tapatalk 2
#2
by
jboogie13
on 07 Jul, 2013 16:52
Diesel purge the pump just for good measure, friend of mine has a 7.3 IDI, those trucks are awesome.
#3
by
mzak88
on 07 Jul, 2013 20:16
The factory water separator has to go, if it hasn't already. They always leak air into fuel system, being on the vacuum side. Stanadyne FM 100 is awesome. Consider an electric lift pump at the tank(s).
#4
by
wdkingery
on 07 Jul, 2013 20:23
I am afraid that removing the water separator is what got me in this situation.. Cause I never replaced it with anything! The owner was supposed to get a screw one type with a separator as part of it.
I think something inside the pump has snapped. It runs just great. Idles fine. Just has no power. Basically have to floor it, isn't making any egt, won't really produce any boost. I mean it will make a pound or 2 when you really wring it out but.. It's like I'm not pushing the pedal hard enough. I just don't know what's inside the pump to know
#5
by
jboogie13
on 08 Jul, 2013 05:05
If i remember correctly, the pumps for those trucks are relatively inexpensive compared to the VW pumps. Hopefully it doesn't come to that, but if it does you can keep your legs and just sell an arm
#6
by
on 08 Jul, 2013 05:39
are those the ones that the IP runs off oil pressure? If so and you have an oil leak at the back of the engine that could be it too. I would do the simple filter and the other stuff suggested too.
#7
by
on 08 Jul, 2013 08:22
Low/no power and low boost on a diesel means not enough fuel. If it is running at all I'd be shocked to find the cause was something physically broken in the pump. Fuel starvation on the other hand....
Rule out the simple stuff before going off the deep end!
#8
by
jboogie13
on 08 Jul, 2013 09:04
No, the powerstrokes (DI) use the oil pressure to control injection. The Ip is still a rotary pump but is lower pressure because the final pressurization of fuel happens at the injector. It's a pretty neat process IMO.
#9
by
mzak88
on 08 Jul, 2013 09:50
Get a stanadyne or racor water separator/filter head. Cheap insurance regardless. You can get them both with integral priming pumps, water bowls, heaters etc. even an electric lift pump built in on the Stan.
#10
by
on 15 Jul, 2013 11:42
I'd imagine that the stock lift pump failed. It's bolted onto the block I think on the drivers side. Check the oil to see if it's diluted with fuel.
You can check the fuel pressure at the fuel filter. There is a fitting on the filter housing for checking the pressure. You will kill the IP if you run it without the lift pump, it is not capable of pulling fuel on it's own from the tank.
Worst comes to worst, sell me the turbo goodies, my 84 is a bit slow
It's been a while since I had any of these pumps apart but I'm doubtful that something is broken inside the pump.
#11
by
wdkingery
on 15 Jul, 2013 11:49
yes i'm a bloomin freekin idiot, as it's likely that is what's wrong with it, and so what do i do? assume it's bad fuel, and go run it for 4 or 5 gallons. hopefully i have not managed to damage the IP this way. idiot. but i just put a quality chinese autozone lift pump on this thing not long ago.. less than a year
#12
by
on 15 Jul, 2013 12:52
The tank sending unit and switch valves both can cause problems too, as well as rats occasionally get a taste for the nylon fuel hose.
#13
by
wdkingery
on 24 Jul, 2013 15:52
it doesn't appear to be
it appears that the lift pump is ok sadly.. i pushed the bike tire fitting in on the side of the filter housing, and it pissed fuel, and the truck didn't even miss a beat.. so it seems the lift pump is bringing up fuel. damn. do you have any more thoughts? i really thought i was going to go fix this..
#14
by
on 25 Jul, 2013 15:35
It's a pain but you might try a local fuel shop to see if they will bench test your pump. Maybe something did let go. I can't picture the insides of the pump anymore though...
