its for a 1.9 td with gt2052 turbo.should be fun
i plan on using the aaz advance parts and the land rover cover for extra travel.
ok,snaped some pics and new questions.
can see that the 11mm plunger has some extra holes in diferents shapes than the gtd one.any special alignment is needed or just align with the pin on the camplate?
the land rover pump missed the small springs on the pump head,is best to use the aaz or 1.6?
here you can see the difference of the land rover and aaz cover being the land rover more than twice as deep.
on the right is the springs.
from left to right is land rover,aaz,1.6gtd.
the land rover is taller than the vw ones.
aaz is silver and gtd is bronze.
if i use vw ones they will float inside the pump...what now?shims to compensate?
and the shim on top of plunger,i will use the one from aaz,as this is the camplate that i will be using,as i thinking right?
