Now how much boost can these engines take? I was planning on running 30 psi on my 1.6 with that pressure would the t3 be better?
turbos can only flow so much, a lot of times you will get more power with less boost.
If you really want huge psi, you need compound turbos.
x2...
not many turbos out there that are very efficient at 30 psi..
x2...
did you ever see the solid lifter ALH tdi on tdi club, running a cummins 4bt pump and 75psi. compound turbo. Dyno'ed at 450whp IRCC
x2...
was it Andy2's car? mk3 golf drag car?
i know andy2 has a cast iron headed alh with compounds and a 4 BTA pump..
a regular old 4BT pump isnt much different from our bosch VE..
the 4BTA got a bosch inline P7100 pump, and thats whats on andy2's car..
if its an engine from a different owner, then i want some links to the topic please?
so whats the best option?
just the stock k03 with the wastegate actuator topped out?
i might rig up a drain line and try both and see whats up. i feel like i'd rather the boost be at higher rpm. that way i'm not always in boost in the city. i don't need all my boost driving down side streets, i'd rather open it up and feel the boost at the top end. with the governer mod and the T3 it seems that would work well. that way i get the boost when i need it... like opening it up getting on an on ramp for a high way. or top end of 4th gear.
if this is what i'm after would the T3 be a better option than the k03?
Have you in fact confirmed that you have a K03? If you do, it's not as easy as just fabbing the return line, you need to change exhaust manifolds, downpipes, charge hoses and intake boots. Plus the intake manifold will need some mild grinding to get the turbo to fit.
From the sounds of it you want to run under 15psi right? If so, go with the K14.
^^^^^^ Do that...
I'm towing a trailer on Jezzie right now with her K24. Getting the car moving on a hill takes a millenia and leaves a good smoke cloud. Smaller turbo would be waaaaay better. The only reason to go for the T3/K24 is that you are planning on running 20+ PSI.
^^^^^^ Do that...
yes, EXACTLY!
i have a small, VNT15 turbo on my car, and i love it. boosts low, and pulls high..
