In the summer I picked up a 91 audi V8 for my mother. It was immaculate and very well priced. And goes like hell!
After doing some research into the Audi v8 I found out it was essentially two vw 1,8 16v's put together.
This got me thinking of the dark side.
Is it possible to convert one of the 3.6's or even 4.2 to td by swapping the heads off of a aaz or 1.6 td, pistons, and some fancy crank work (not to mention plumbing, timing....etc).
I have seen these motors making HUGE power, but could they take the abuse of running a relatively low compression (16.5-18:1) twin turbo diesel setup.?
why not use the V8 TDI?
350 HP V8 TDI marine engine.thats the marine version, but they gotta make a normal version if they make a marine version.
heres some technical info, bore, stroke, all the fun stuff.. surprise surprise, it has a VNT on it..
V8 TDI Tech Info
VW Marine !!!! OMG !!!!!!
Daddy needs a new boat motor !!!!
my thoughts exactly, when i first saw VW marine..
-00-01 Audi A8 had 3,3 V8 TDI from factory. 4-valve heads, twin-vnt's, commonrail...
Why not use the v10 from a toureg?
its probably MUCH more expensive than a V8 TDI..
