Common VW turbo inlet/outlet sizes?
by
Smokey Eddy
on 24 Nov, 2010 21:52
What are the sizes (inlet and outlet) of the kkk 24, kkk 14 and a Garret T3?
Looking to order silicone couplers for said turbos.
thanks.
#1
by
on 25 Nov, 2010 06:51
K24 is around 2.5IIRC The inside is small but the coupler will need to go over it all. IIRC what I bought it 2.5. The T3 should be the same. K14 I have no idea. That is just for the air cleaner to turbo. The Exhaust to downpipe is around 2" or so. The boost pressure out let
GB will know I am sure
#2
by
rodpaslow
on 25 Nov, 2010 07:56
I know the outlet on a T3 is a bit smaller than 2", but I use a 2" coupler and seems to work fine. I think the inlet is about the same.
#3
by
Dakotakid
on 25 Nov, 2010 08:47
KKK 24:
Inlet is 60 mm.
Outlet is 50 mm. (outside measurement)
#4
by
arsenicpants
on 26 Nov, 2010 10:06
k14 is 1.875 both in and out i think
in I know for sure
i'll check when i get home
#5
by
AudiVWguy
on 28 Nov, 2010 09:50
I started a thread called "Manifolds and turbos" , it has some helpful pictures. (good luck with the search function)
Cheers,
-JB
#6
by
GEE-BEE
on 28 Nov, 2010 11:42
Turbo Duct( turbo to Intake manifold )
T2/T3/K14/K24 : 46 MM TO 49 MM
KO3 1.50 TO 2.33
EBAY ITEM 220624177746
Turbo Inlet from Snorkel
KO3 1.85
T2/T3/K14/K14 2.33
Snorkel here MK1:ebay item 220679730082
MKII is in production..
I know , cause I make them...
GB
#7
by
RadoTD
on 28 Nov, 2010 16:50
So K24 is on the 49mm side of that, K14 on the 46mm side... is it better to run a 2" or 1 7/8" on the K14? How stiff are the silicone couplers?
#8
by
GEE-BEE
on 28 Nov, 2010 19:46
Smaller is the turbo side, ( outlet) to the larger size manifold inlet
They dont stretch as much as the epdm rubber..
GB
#9
by
arsenicpants
on 29 Nov, 2010 19:34
i'm running a 2" coupler on my k14, secured with a t-bolt clamp, and it's been fine pushing 18 lbs
#10
by
Thezorn
on 30 Nov, 2010 19:28
X2, make sure you run good quality t-bolt clamps, not cheap ebay kit ones, I snapped 3/4's of the ones my kit came with so I had to go buy some good quality ones.
#11
by
GEE-BEE
on 01 Dec, 2010 06:58
I include 100% stainless steel lined clamps on all my products
The adjustment bolt is s/s also , all made in the USA and is aircraft quality
If you dont use a lined clamp , it will cut into the silicone....
GB
