k03/ko4 talk
by
Mozza
on 24 Aug, 2010 11:22
Ok i have been wondering about what turbo to go for and as one of these can be made up to bolt straight on I like this idea,
Questions are:- Who is running one of these and what are the results and what would i need to build one using my exsisting k03 from my AAZ,
Cheers and let the banter begin, !
#1
by
Smokey Eddy
on 24 Aug, 2010 12:41
GEE-BEE has a k03/k04
#2
by
GEE-BEE
on 24 Aug, 2010 19:53
Correct with ceramic coated housings and full balance
Please give Jerry at GPOPSHOP.com a Jingle
Tell him I sent you ....
P.S. Performance is amazing with this , several people have infomed me how quick this truck is
It ate a 3 series BMW the other night to 92 mph, made a new Titan driver cry....
GB
#3
by
MJF
on 25 Aug, 2010 00:20
We need performance numbers. We cant know if that 3 series BMW was 316 or M3.
#4
by
Mozza
on 25 Aug, 2010 03:56
Superb, I will get incontact with him asap!
#5
by
blackdogvan
on 25 Aug, 2010 09:26
BG's is backwards (not that thats necessarily a bad thing) from the "standard" K03 hybrid that Kerma or Bora sell BTW. I believe his is a Ko4 hot side & K03 cold side, the vendors sell a K03 hot side with K04 cold side guts in a massaged K03 compressor housing. BG's will flow better at higher RPM while the other will have less lag. I believe they have a very similar shaft & bearing sizes in both.
#6
by
GEE-BEE
on 25 Aug, 2010 10:09
That's GB
if it was BG I could sing....
K04 hot/Ko3 cold is correct
Gee-Bee
Was 915.00 with all the stuff done, housings, balance
I sent three cores and i got a 150.00 credit
it was a business expense ( truck) full write off....
#7
by
Smokey Eddy
on 25 Aug, 2010 10:41
So what pressure do you limit that hybrid to?
#8
by
GEE-BEE
on 25 Aug, 2010 11:55
Iam at 22psi, until IC
GB
#9
by
Mozza
on 02 Sep, 2010 17:08
is the build of this sory of hybris domething you could do your self if so what would be involved!
#10
by
gldgti
on 03 Sep, 2010 05:56
In my bud's M-tdi build, we got a prothe K04 and I bought a genuine k04 meant for an isuzu i think. the genuine one had all the wrong housings but basically we used the prothe housings with the genuine core. all we needed to do was space out the exhaust housing 0.9mm from the core.
this diesel k04 is certainly heaps smaller than a gasser k04 but it seemed to be a great size for the 1.9. cold side pretty similar to k14, but with larger inducer diameter, and hot side also similar to k14 but maybe slightly larger exducer diameter.... i forget now. Anyway, spooled pretty well but we never got to test it very well because he sold it before we could really tune it up.
