here is how i have mapped it at 30 psi and reving to 6k, volumetric efficiency at 80% supposedly some where around 180whp, how ever i doubt it will do that much, unless i have good intercooling and very good flowing intake manifold with giles pump. it goes off the map some in the higher rpms, not ideal but the high pressure ratio areas of the compressor maps, are not always mapped because the compressors were not meant to be used on applications with this low of flow and this high of a pressure ratio, so its not necessarily inefficient in those areas, also the choke limit of the maps is generally just where the compressor becomes less than 60% inefficient. loads of people run turbos past the choke limit on here with no ill effects, if we drove gassers where super hot intake air temperatures caused pinging and stuff it would be alot more crucial, but since we drive diesels we can get away with passing the choke limit a bit.
the points on the map represent these rpms in order 1000, 3000, 3400, 3800, 4400, 5000, 5500, 6000
im hoping to have the spool of the vw diesel, with the efficiency and flow of the mercedes turbo. i know a few people have built the
k26/k24 hybrids with poor results, ive looked at the k26 map, and although the 1.6 stays well within the operating range of that compressor it is never in a very efficient part of the map, this coupled with the k24's smaller exhaust housing .30 a/r i believe is what created excessive back pressure which lead to excessive egts. vw t3 exhaust housing is .36 a/r so slightly bigger, and it also has one less blade in the turbine wheel.
