Im getting to the point where i want to figure out my clutch set-up.
I was going to run a 16v pressure plate and 8v disc and a eurospec lightened flywheel. But my shop here can't order in the flywheel till spring. I'm curious what other flywheel will work well with this set-up. Engine is a 1.6TD running higher boost and more fuel. Tranny is the stock 83 020. Engine is still being built. I want something that can handle more then the stock diesel clutch but still feels good.
TIA--
Kane
use a gasser flywheel, just make sure it has a TDC mark.
Clutch purchased. Thank you. Thread can be closed
Ok. So i am installing the clutch today. Set-up is as follows. 16v pressure plate. 8v clutch. 8v flywheel. Problem is when i line up the dowels from the flywheel to the pressure plate my flywheel bolts don't all line up. When i line up the flywheel bolts the dowels don't line up.
Anyone have any ideas? Or something similar happen?
Kane
Ok diesel has 6 flywheel bolts. gas has 9. With the new clutch setup 6 fit around symmetrically I torqued them up but my clutch disc isn't held in "snug" it's still loose any ideas???
hopefully i get this sorted out soon.
Either the FW has been machined to much or the PP is not fully seated to FW
You are using a 9bolt FW and PP right?
dont use a diesel pressure plate or flywheel. use a gas pressure plate for the 9 bolts. and use the gas flywheel cause its like installing a lightened flywheel. they are way thinner than diesel wheels.
i would not just leave 3 bolt holes there with nothing threading into them. and im pretty sure that only the 200mm pp's had 6 bolts.
Yeah something's wrong here for, jumped the gun, excited to finsh it. All nine holes line up but then the dowels dont, dowels line up 6 fw bolts fit. So i believe i have to get my part numbers checked out this afternoon. I dont think the flywheel is right, I have sachs pp and sachs clutch disc but then a luk flywheel and the only thing i can think of is wrong parts were ordered(check part #'s) or the different name brands don't work together. Frustated cause the drive train would have been done this weekend if not for this, also i'll be out $100 also.
I should've ordered a clutch kit instead of ordering it seperatley i guess.
