aaz parts
by
NintendoKD
on 26 Jan, 2010 20:26
I have set out to find replacement/oem parts for the ever illusive aaz engine. I am located in the states, and for those of us in the states that need these parts it is really difficult to find what we need. I thought that also we should start to put up performance aaz sections in the FAQ section, I of course, volunteer, as over time these engines will eventually trickle over the border and more enthusiasts will be looking for performance options. So far I have found a Canadian seller:
http://www.importcarpartscanada.cathanks, and hopefully, there is support from both the other side of the pond and from our friends in CANADA
as a reference the aaz was in the following cars in the following years:
Audi 80 (09/91-07/95), Volkswagen Golf, Volkswagen Transporter (T4), Volkswagen Passat, SEAT Ibiza Mk2 (02/93-08/97), SEAT Cordoba (09/93-08/97), SEAT Toledo (05/91-04/97)
some of these cars were only featured in europe, and some only in canada.
Kevin
#1
by
Henchman
on 26 Jan, 2010 20:46
What do you need? I have 3 shorts and 1 complete engine sitting in my driveway? And the website is just a storefront for the usual suspects online parts suppliers. As for performance parts, well, few and far between. Mostly homegrown. Wanna go faster, more fuel more boost. IMHO.
Ian
#2
by
NintendoKD
on 26 Jan, 2010 21:00
I need to completely rebuild a cyl head. I already have thehead but will need new everything, cam followers, cam key, valve stem seals, valve guides, sensors, gaskets, everything save the head and valves and cam. I also ave the valve cover for one but not the other. Also wondering what that rubber thing is on top of the valve cover and what in the world I'm supposed to do with it? Who are the usual suspects? I am unaware of the manufacturers, and products for this engine, as this is my very first build.
thanks,
Kevin
#3
by
on 26 Jan, 2010 21:20
#4
by
NintendoKD
on 26 Jan, 2010 21:39
hey, thanks vince
good to know, still need more than what they have online, I'll try calling tomorrow.
thanks,
Kevin
#5
by
on 26 Jan, 2010 22:01
Yeah, even in the last 6 months it seems the Worldpac inventories are going down, and the prices are definitely up.
#6
by
NintendoKD
on 26 Jan, 2010 22:19
#7
by
GEE-BEE
on 27 Jan, 2010 06:52
It's the rubber breather grommet ( valve Cover )
I have a complete valve cover with a cap if you need one..
GB
#8
by
55eta
on 27 Jan, 2010 12:53
the vw transporter t4 used the abl engine very similar to the aaz but it has the dip stick hole on the back of the block and a different cylinder head and m10 engine mounting bolts [timing belt end] i made the mistake of buying a aaz fro a t4 and found out this the hard way but got it to fit in the end ,almost forgot the IP bracket is different to
#9
by
NintendoKD
on 28 Jan, 2010 05:50
GB
I'll take you up on that
#10
by
NintendoKD
on 29 Jan, 2010 11:23
#11
by
on 29 Jan, 2010 22:16
#12
by
NintendoKD
on 30 Jan, 2010 08:03
After a complete rebuild and machining, I still won't have paid that much. 700 bones
that, my friend, is a lot of dough. That is the sole reason that I bought one from someone in the classifieds, got a heck of a deal.
#13
by
on 30 Jan, 2010 08:26
i would have taken the new head had i been in your situation, and been dumping so much money into the engine, i would have spent the extra money. cause how much of your own time do you have in it? sure your time doesnt cost YOU anything, but its still effort that has to be done. i know it takes alot of time to do a full thorough rebuild on a head. 700 isnt bad is its a BRAND NEW VW head.
#14
by
GEE-BEE
on 30 Jan, 2010 08:35
I found a new one complete with valve coverassy in the factory for 375.00, paid the 150.00 for a new set of complete 155 injectors and I sent them to Giles along with my pump for a performance overhaul
( trade ) for a new T3
My head was the same stamped vw mexico.
I would of kept, but a member back east called and needed one bad so off it went.
I will probly find another complete head later this year when I return to Germany, I would rather have a German head assy for that price.. ( 675.00 )
Now moving onto another project...
P.S. I do have a super clean german ( import )AAZ pump if you are looking ( core ) not rusty
Gee-Bee
