Todd,
I've been torn between jb weld and just plain ole aluminum weld.. Maybe I'll just try both, I have plenty of housings... My luck in the past with drilling and tapping JB weld has been poor at best, I usually end of breaking it.. I guess a tad more patience is in order...
Folks, let's still treat this as a potential epic fail.. I don;t wanna jinx it..
The guys at the machine shop don't even want remotely associated with this abortion, although they did give me the rods... However, 90 miles on the same coolant.. No coolant loss, no over heating, no signs of oil...
I guess I have been running the detergents for quite some time.. I guess the head showed no signs since it's been coated in the oil floating up top, and it's a better grade of aluminum than the water pump housing... Geez, I wonder what the rad and heater core look like? I have the WVO heat exchangers removed to go take a bath in the hot tank to remove the goo...
The temp will drop down to about 140 at times.. Then again I guess it has always done that.. Just gotten worse in teh last year.. Gotta give her hell to keep it warm, what a shame... Once thing noticiably different is that I FINALLY have some heat.. The stat I have in there now is a mystery stat out of my pile of junk... It's a 180F, gonna grab a 190 for it tomorrow when I flush the coolant and try some antifreeze in it..
I really wish I would have done this in the summer months.. I'd like to push it hard on a hot day and see what happens.. That and I wouldn't have to worry about wasting antifreeze if it left go..
The best part is I'm not out a whole lot if it doesn;t hold.. The head gasket and welding rods were freebies.. I already had the reusable v/c gasket and head studs.. I bought oil and filter, heat shields, hylomar, gallon of antifreeze, t-stat, had the jb weld on hand.. I guess I also had a water pump in there too, although that wasn;t all that necessary with the corrosion I figured it couldn;t hurt.. The engine was junk when I drove it in the garage... Worst case scenario, it would still be junk when I pushed it out.. It may still be junk, time will tell, and AAA is there if time tells me it is..
I had promised some pics of the finished block deck earlier.. You can sort of see the pits I filled in with JB weld.. Some of those were actually there before the grinding and welding....
Funny thing, I see in the 2nd to last pic I have a torn boot on the steering rack, that's the first I noticed..
