turbo compressor nut torque?
by
jwspin
on 22 Jun, 2009 15:35
what should i torque the nut to on my compressor wheel on a k14 turbo from an eco diesel?
thanks
-jared
#1
by
jwspin
on 23 Jun, 2009 06:35
nobody? i need to get this turbo back together today.....
thanks in advance
-jared
#2
by
arb
on 23 Jun, 2009 07:01
I see no one on Vortex answered either... Did you try calling a local turbo shop and ask them? Maybe call the guys you got the rebuild parts from ?
#3
by
jwspin
on 23 Jun, 2009 07:16
yeh i might have to, i remember that a few years ago on here a bunch of folks were rebuilding turbos and i was hoping someone would chime in...
#4
by
jwspin
on 23 Jun, 2009 08:20
yeh this turbo was taken apart years ago and i cant find where everything was written down. can you remember what torque numbers have you used? i read somewhere that on a t3 you hand tighten onto the nut and then add another 1/4 turn. i figured there was something similar for the kkk turbos....
#5
by
on 23 Jun, 2009 11:14
the k24 is 28" lbs + 1/4 turn,
The k14 however has a MUCH smaller shaft size.
Better talk to a vendor to get the correct specs.
#6
by
jwspin
on 24 Jun, 2009 09:08
is the guy still on here that sold the dieselicious rebuild kits? thats the one i got maybe he would know the torque spec. i think his name was jake.
-jared
#7
by
rabbitman
on 24 Jun, 2009 12:50
Nope, hasn't been on here for a few years. Sorely missed also.
uh huh
#8
by
on 24 Jun, 2009 14:58
don't you need to properly orientate the nut for proper balancing as well?
#9
by
jwspin
on 25 Jun, 2009 06:41
if the nut is ground you do. i had a t3 that you could tell had been balanced as a unit because the nut and compressor wheel were ground together. does anyone else have any good turbo contacts if jake is not around?
thanks
-jared
