Aaron, any progress on your van?
I dismantled my trans yesterday to get the input shaft out for shortening, (on the Syncro, you have to take out at least one side-carrier to shift the differential out of the way, otherwise you can't get the input shaft out) and to put on the DV bellhousing. I'm also waiting for a de-coupler from Germany, so the nosecone is off too.
I've been thinking about gearing, with the gasser tranny it's gonna be way low... I'm on 235/75-15s now, and I'm considering going to 235/85-16s. Rubber gearing. I have to try it before I spring for a real re-gear, see if the highway revs are acceptable... might kill the crawling ability, though.
I'm going to try and chuck the shaft into my drill press for rotation, and hold a cutting wheel still at the 1/2" mark, then use a grinder
to restore the taper to the tip. Home machine shop
I bought a few AAZ things from Brickwerks to make life easier; their oil return hose, block bung, the throttle lever kit, and the Rover fuel pin... I had to route it to Paris, where my wife is visiting a cousin, they won't ship to N. America.
I was sifting thru the pile in the garage, & I have another set of Syncro mount bars, if you need 'em.
I picked up an A2 diesel tach from another member here, and transferred the guts into the Vanagon tach housing. Pretty easy, once you get the needle off the shaft. Replaced the red OXS LED with the yellow glow-plug LED. I want to find, or make a new light icon insert w/ the glo-plug element on it.
That's about it so far, I hope to really dig into some stuff this weekend.
