I totally understand the difference between the gasser need for a BOV and all that. But, the pump slows down to idle after letting off the throttle. Also, with the pump causing the engine to return to idle, doesnt that mean that the valves and pistons slow down?
As we all know, the engine is essentially a pump within itself. So if we slow the pump down then we are processing less air, no? Exhaust and intake alike.
The reason I am interested in this is because I believe I am getting a pretty fair amount of surge after letting off the throttle. Example, 1st gear pull to get to second, then WOT up to 4500 rpm and then let off the throttle. Hence the warbling noise. So if pressure could be vented somehow that might alleviate stress on the turbo. I plan on using a gt25 on the next engine and I dont it to break the shaft. Especially @ 30+psi.
The engine slows down more slowly that the turbo. There is allot of rotating mass in the engine, so RPM doesn't plumit. As a result, I suspect the boost falls faster then engine RPM. The engine just pumps the 'excess' boost right through. No harm, no fowl. If you leave the engine in gear, it slows down even slower.
I'm haveing a hard time correlating 'warble' to a compressor stall. Compressor stalls tend to make sudden sounds like repeated thump or wump sounds.
I had a K24, that I was running just under 30 PSI, lose a section of a trailing edge of one turbine blade. It made all kinds of bizzar noises above ten PSI after it crapped the blade piece out of the tail pipe. I actually heard the piece of blade go rattling down the pipe, so I was able to mark the difference in sounds after word. It still made boost, but it also made some really strange noise too, and warbling could have been one of them.
You may want to look at your turbine blades and see if everything is OK in there.
Here is the photos of the blade failure:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=14895&highlight=This is a turbo that lived well above 20 PSI for three years. It even had new journal and thrust bearings. The shaft didn't snap, the compressore didn't throw a blade, it never had a compressore stall, and it only lost a small part on one blade.
I suspect the compressore stall problem on the big pick up trucks stems from turbos big enough to injest our tiny turbos, with significant rotating mass, making HUGH boost, on low RPM motors.
Oh, and they have huge "accumulators" (intercoolers) that may not bleed down as fast as out teeny manifolds.
