#90
by
blackdogvan
on 28 Jun, 2008 12:56
Does anyone have any before and or after dyno numbers for an AAZ with a Giles pump? I've found lots of VERY positive reviews, definatly enough for me to feel very comfortable getting one, I'd just like to see some numbers to go with the "ass dyno" numbers already posted.
This thread was a great read BTW!
#91
by
on 28 Jun, 2008 13:41
It's a 1.9TD stock governor............ around 4500 look what appens, maybee higher for 1.6.
http://ca.youtube.com/watch?v=6j0vrfaXPmw
That's not the case with my pump, it defuels at 3500 and @ 3900 its done.
Steel sleeve where the spring used to be as well BTW.
#92
by
on 30 Jun, 2008 09:49
Just filled up again,
51 miles per US gallon
4.6l/100kms
61.4 miles per CAN gallon
70% highway
Very impressed.
#93
by
on 30 Jun, 2008 11:41
Dang that's really good..
I'm saving up for a Giles pump. Gonna take some time but i'm getting one!!
#94
by
dieselwagen
on 30 Jun, 2008 16:52
4.6l/100kms
70% highway
Very impressed.
the MPG gain is equally impressive from your oem IP previous best
diesel IP truly = PCM on gassers. did you say smoke got minimize on acceleration.
got 1st diesel car 2 yrs ago and still in school on diesel IP
in gasser terms its hard to tune for gains in both power and MPG
mr. Giles is on top of his game
#95
by
on 30 Jun, 2008 18:35
yeah I used to have very small amounts of smoke but it's pretty bad right now. I think my fuel filter is clogged, air filter needs changing and the injectors need to be replaced. I think I filled up with some very crappy diesel last time
#96
by
nokivasara
on 01 Jul, 2008 04:59
I think itīs the advanced timing that increases both power and mileage. But itīs a thin line where itīs optimal, too far advanced and the cyl pressure and temp skyrocket. I guess Giles has done a few hours on the test bench...
I turned up the fueling on my Lucas IP, it adds the fuel in front of the injection stroke advancing the timing at the same time and I got more power for less fuel too!
#97
by
zozep
on 01 Jul, 2008 14:02
I "raced" my cars twin last night. Basically it was a 91 Golf with a 1.6 NA. His pump was rebuilt 15000 ago by some shop and he has my old tranny, the POS AWY short ratio thing. We met up on the side of the road to discuss an engine swap and then decided to carry on to the nearby gas station. He was ahead of me and he pulled out and then I followed. I could see by all the black smoke he was foot to the floor, so I followed suit. With his short ratios he was able to slightly pull away from me in first and second (for me, probably second/third for him) but then I started coming up on him FAST. haha. I didn't pass him because we weren't really racing and the last thing I want is a racing charge. We were on a 2 lane highway. No excessive speed was involved, just accelerating hard up to about 20km over the limit. We were both still "racing" when I had to back off, it's not like he hit "top speed" and slowed down and that is why I caught him.
We drove each others cars after and he definitely was impressed
Yes I was definitely Impressed, although his car has less mileage, and has probably been better cared for, there was a huge difference drive-ability... Aside from the lack of Power Steering
For anyone who wants to know the story here, I've been wanting more power to my little 1.6n/a for some time. Looked into adding turbo, but a swap seems to make much more sense....
From some stroke of luck I got in touch with Tyler, we talked and agreed on swapping out my tired, and very smokey 400+Kms 1.6 with a fresher 1.6TD on it a Giles pump and maybe a few other recommendations from Tyler, Bigger down pipe? Increase to 20PSI?
Anyway, I look forward to this new chapter in my Golfs life. The numbers to this one will come.
I will most likely be giving whats left of my engine to Tyler, and so he will have a Bosch rebuilt pump, rebuilt about 15k-20k ago...
#98
by
on 01 Jul, 2008 16:50
I think your engine will have better compression then mine, and mine has sat for the last 5 years so it's not in the best of health.
Power Steering is over rated
#99
by
dieselsmoke
on 13 Aug, 2008 08:16
I am going to have my 1.9 AAZ TD engine rebuilt and was looking at getting a Giles pump. Does anyone have numbers with one of his pumps on a 1.9? Is there anything I should have done different during the engine rebuild to help out to get better numbers? What kind of injectors should I use, the GTD or the mercedes ones? ANy input would be great. Thanks
#100
by
on 13 Aug, 2008 09:51
Call Giles at the shop and talk to him about it.
905-940-2266
On my brothers AAZ, I had a mild pump built for him and off boost there was no difference (as designed) but once the boost hit, you knew there was a turbo :twisted:
#101
by
dieselsmoke
on 13 Aug, 2008 09:55
will do. sounds like you can make a monster out of one of these 1.9 AAZ engines.
#102
by
on 13 Aug, 2008 14:20
burn out video?
#103
by
on 13 Aug, 2008 14:51
#104
by
on 13 Aug, 2008 15:47
maybe once I get my tach hooked up again.
