1.9 TD real power
by
flash319
on 25 Dec, 2007 07:29
What should I expect from a 1.9L TD (IDI) power wise? If I fuel it up what sort of HP would I see? Could I see 110+ HP with pump mods and intercooler? 180 lb/f torque? Realalistic numbers not BS.
#1
by
haybayian
on 25 Dec, 2007 13:23
The AAZ is rated 78 HP by the manufacturer and I believe about 100 lbs/ft torque. I was told by the shop that modified my IP that I should expect a 20 HP gain. I am going to run an intercooler , performance air filter, as well as a larger exhaust line. My hope is to crank between 100 and 110 HP. But I may be BS myself. I would like to hear from others.
Haybayian
#2
by
bert
on 25 Dec, 2007 16:06
My AAZ is unbelievably rapid,i dont know any figures yet but wow what a performer,all i have done is used a T3 from a 1.6TD and fitted a rover 220TD aneroid pin,and a 2.5" exhaust,im well happy with it,no intercooler either,i run at 11psi full chat.Hope this helps
Bert
#3
by
vanagonturbo
on 25 Dec, 2007 21:13
I dont think getting 180 ft lbs will be very feasible for a DD. Not to hard to acheive but also hard on the engine. I might also point out that my experience at this point pertains to my 5k lb Syncro vanagon with an AAZ.
#4
by
carrizog60
on 26 Dec, 2007 03:09
1.6d converted to td:
boost pin reshaped,merc 220cdi intercooler,increased fuel in pump,merc dn261 nozzles,blocked WG with kkk24 running 30psi=136hp at the flywheel.
so you can see 110hp ate pretty easy to achieve.
#5
by
MJF
on 26 Dec, 2007 03:21
Why so much boost? You could get that much power with half that boost. Itīs just stressing the motor :roll:
#6
by
carrizog60
on 26 Dec, 2007 04:42
to clear out the smoke...
i prefer on having a better combustion than a smokey one ...
it also helps keep egt down.
even i only get 30 psi at redline(bloked WG)
#7
by
flash319
on 26 Dec, 2007 05:45
Ya I think 180f/lb is a bit high. I would be more then happy with 140. Thanks for the info so far...............
#8
by
on 26 Dec, 2007 06:44
I think 140 ft/lbs would be easily obtainable. My AAZ is in a 4wd with losses of both an extra overdrive, transfer case and 32" tires. With the fuel not turned up much if any(previous owner said it was turned up a little) I dynoed at 80 hp and 122.5 ft/lbs.
#9
by
flash319
on 26 Dec, 2007 06:55
Jimfoo, My plan is for putting a AAZ out of my 97 Jetta (1.9L K03 Turbo) into a 4X4 Toyota truck. What is yours in? I have been planing this for a while but I get some people saying it will be horribly under powered and others saying it will be fine (these guys have 1.6L in Samys). I have a 22RE in the truck now and it is rated at 110hp and 140ft/lb (Peak HP is at 3800rpm, Peak torque is 3200rpm). If I can match that then I would be more then happy. I just don't want to dive into this without knowing what the end result is going to be.
PS sorry just read what you have it in................
#10
by
on 26 Dec, 2007 07:08
The only problem I had was for some reason I never figured out my engine got really hot going up long hills/passes. It could have been my radiator was just a bit too small, thermostat or water pump problem, I never really found out. So I would have to go much slower up hills than I otherwise could have to try to keep the engine cool. My truck weighs 3500 lbs and my old gas engine had 42 hp@3500 and 83 ft/lbs@1500, so to me the power was great. I got close to 30 pg on the highway, but I'm shaped like a brick. I would thing a Toy would do a bit better, especially if the gearing is better, which I think it is. My truck has 4.7's so I'm doing about 3k rpm at 65. My AAZ's torque and HP peak was around 3500 rpm. If I didn't have the heat problem, I'm sure I could have turned the fuel up more and done even better., plus my radiator size was limited to about 18-20" width. You could probably fit a bigger one if you needed.
#11
by
nogama3
on 28 Dec, 2007 05:56
i have a 1.9 aaz TD engine and have upped the boost and added an intercooler from a Golf mk3 TDI and am now running at 100bhp (1.0bar boost). looking at adding a larger sharan intercooler on the front in the future - its sitting in the garage at the moment.
