And just how close to Salt Lake City, UT is that?
Dig out your Bently and go step by step.
1) DISCONECT THE BATTERY GROUND CABLE!!!!!!!!!!!!!!!!!!!!!!!
(yep, very immportant!)
2) Remove the hard lines to injectors (17 mm wench should help [of the
tube type])
3) Starting with #4 (passenger side) remove the nut on the end of the
glow plug (an 8mm wench here) (Yes we did the hardest first).
4) With all the nuts removed, gently ripp that damn buss pos out of the
way! Or just tickle it until it falls out.
5) Remove glow plugs (Hmmmm lost another wench, cheeky darn
thing! :oops:
6) Check to see if you have fast plugs or slow plugs. Slow plugs are 9
Amp, fast are 15 Amps. DO NOT USE FAST IN SLOW, OR SLOW
IN FAST SETUP!!!!!!!!!!!! One will burn up your glow plugs FAST, and
the othe will never get the job done.
7) TEST your NEW glow plugs. Jumper wire from terminal to + battery,
theads to neg side, 10 seconds should be "GLOWING". Just because
they are new, does not mean they work.
Install NEW TESTED glow plugs, starting once again with #4. (If you do
the hard ones first, you are less likely to be fusterated and mess up.)
9) Replace the glow plug buss strip. (Or REPLACE the glow plug buss strip
with some #8 wire with the proper terminals on it. 4 plugs, 4 wires
all going to the fuse there. Or thru a relay setup like..[Ooops, thats
a different post!])
10) Reinstall hard lines to injetors (Where did that cheeky bit go?)
11) Reconect battery ground. (Okay, what did we forget this time?
Hummm....... Got that, that and .... that. Just checking!)
12)..................Oh Yea, start car! (You DID pick up ALL your tools and
wenches, no?) :twisted:
That's how to replace glow plugs, Wheather that was your problem or not......? :roll:
FOUND IT!!! That paricular wench looks alot like 12mm! :lol:
A case of San Migael Dark souds good to me.
