The GOOD thing about the serp belt though is it makes for way easier belt changes plus it opens you up to the world of high output alternators. No re-tensioning either. FWIW it isn't so much the letting off the pedal that is the issue as it is the pulses of power as pistons speed up on the combustion stroke and slow down on the compression stroke. Hammers the hell out of the keyway on the crank sprocket. The "D" style is a million times better.
Scarry stuff but I'm glad people are capable of it. I have yet to remove the crank bolt on the AAZ in the 82. Plan to avoid it as long as possible.And to stay with V belts.
wolf-walker, Wondering if you would provide more info on using the V belt and V belt pulleys on your aaz? I have done lots of reading on this and yes, that counter-rotational force from the alternator inertia via the serp belt is a keyway killer. I want to stay clear of the serp belt set up for sure.
Quote from: Spokerider on January 08, 2014, 01:17:43 pmOn the Quantum, the fixed distance for the crank to water pump is overcome by a split pulley on the crank, that has say 10 [9 actually] shims available that are stored behind the pulley as they are removed from in between the pulley, to progressively squeeze the v belt, making the belt try and climb out of the pulley, effectively increasing the diameter of the pulley, and so the tension increases...Very cool. I think the Quantum in Canada was labeled as a Passat. Do you know what year Quantum had the split pulley? I can check that year Passat at the wreckers. I was just going to roll a belt or two, or three, over and into the water pump / crank pulleys, and choose the belt that had the optimum tension. Checked with 2 machine shops so far regarding the crank repair...... one declined the job as they have no C&C machine, the other shop wants to just cut the same keyway notch 180 deg from the original, and install a new sprocket ......even after I explained that the crank was not buggered [ yet ] and how I wanted the repair done as per TDI sprocket. Spray welding was a no-go for this shop. I have another machine shop to pester yet.
