Author Topic: Oil pan mating surface corrosion on block  (Read 5232 times)
July 11, 2023, 11:48:11 am
oblique
  • 317
    Diesel while you can.
« on: July 11, 2023, 11:48:11 am »
This is an unused Aaz block, everything looks fine on it except this one really bad spot...is there a good way to repair this or do i just rtv it each time?
Humbly rolling coal.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #1July 11, 2023, 07:10:11 pm
  • 4553
Re: Oil pan mating surface corrosion on block
« Reply #1 on: July 11, 2023, 07:10:11 pm »
I wonder if you couldn't put some body filler in there.  One with more metal in it.  Otherwise, RTV if it holds.  I mean how often are you planning to expose it?
Reply #2July 12, 2023, 10:10:19 am
MeidleMose
  • 3
« Reply #2 on: July 12, 2023, 10:10:19 am »
I wonder if that was a victim of the infamous incident in which several dozen AAZ blocks literally fell off the back of a truck at one of VW's assembly plants ...?
I've never used JB Weld for anything that large, but considering the rather non-critical location and purpose (relatively speaking), I might consider it for this repair. Build it up and then carefully file/sand it flat to match the adjacent flange area.
I would also recommend the installation of an oil-sump baffle/windage tray with heavy integrated rubber gasket:
https://www.urotuning.com/products/oil-pan-gasket-w-baffle-pre-1999-4-cyl-037115220b
Reply #3July 12, 2023, 02:54:29 pm
oblique
  • 317
« Reply #3 on: July 12, 2023, 02:54:29 pm »
I will clean it up best I can and just try rtv first, see how it goes.
Yes, origins unknown. I got it from a guy who got it from a guy who got it from...a guy. Came with a bunch more bits, although a bunch was AHU. Almost seems like someone was trying to put a motor together...maybe I will be that someone.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #4July 12, 2023, 10:28:35 pm
  • 2932
« Reply #4 on: July 12, 2023, 10:28:35 pm »
I use the reusable rubber, MK3 2.0 gasser oil pan gaskets.
 You could use great stuff to build up and attach the gasket to the block and put no gasket sealer on the other side so the pan would come off easily.
 Then you wouldn't have to reapply the sealant every time the pan came off,.. which I hope isn't often anyway, ha.
Reply #5July 13, 2023, 06:25:32 am
oblique
  • 317
« Reply #5 on: July 13, 2023, 06:25:32 am »
I do have some of the baffles Meidle linked to, guess Ill rtv that to the block.
The one super corroded pan bolt hole...i think the threads are gone, assuming i should helicoil that or tapmit up to the next size and forever be looking for that bolt.
90 1.6TD Jetta
79 1.6Na Rabbit
Reply #6July 13, 2023, 03:10:11 pm
oblique
  • 317
« Reply #6 on: July 13, 2023, 03:10:11 pm »
Just measured the bores on this thing...all are right about 79.90mm at the top...whoops (pistons are 79.48). i didnt think bores tapered..either I have a new block that someone honed or a factory oversize, if those exist.
90 1.6TD Jetta
79 1.6Na Rabbit
