Author Topic: Land Rover pump timing question  (Read 6291 times)
October 10, 2021, 04:19:55 pm
DaveInWa
  • 4
« on: October 10, 2021, 04:19:55 pm »
Hi,
I have a 1Z and am installing an LR300 pump for my mk1 pickup. I have read most all of the other posts, but I was a bonehead and forgot to lock the shaft before I removed the (keyless) hub from the (keyed) shaft. So now all I have is the 4 position detent of the cam plate to go off of, and the location of the key slot on the shaft.
So, how can I get the pump into the ballpark correct place to set the hub back on?
I guess the good news is that I can now line up the LR "slot" to cylinder 1, where I have read it was at cylinder 4 before, 180* off.
I have tapped a new hole to mount the slotted ALH pulley, so that's how much adjustment I'll have once I set the hub in place.
Thanks,
Dave
Reply #1October 10, 2021, 06:29:08 pm
DaveInWa
  • 4
Re: Land Rover pump timing question
« Reply #1 on: October 10, 2021, 06:29:08 pm »
Maybe I am overthinking this... Point the keyway roughly at the #1 output, use the dial indicator to do the timing, then install the hub so that the locking pin engages at that location? And then install the sprocket/pulley with the bolts in the center of the slots for adjustment in either direction?
Thanks y'all.
Reply #2October 11, 2021, 04:44:28 pm
« Reply #2 on: October 11, 2021, 04:44:28 pm »
Thanks y'all.
You've got it.
Reply #3October 11, 2021, 10:35:48 pm
  • 2932
« Reply #3 on: October 11, 2021, 10:35:48 pm »
 When you say use the dial indicator to do the timing.
 You move the shaft until the dial indicator is at the right place then tighten the locking bolt that holds it there.
Reply #4October 12, 2021, 08:22:00 am
DaveInWa
  • 4
« Reply #4 on: October 12, 2021, 08:22:00 am »
Thank you @libbydiesel, @fatmobile.
Reply #5October 23, 2021, 09:43:18 am
DaveInWa
  • 4
« Reply #5 on: October 23, 2021, 09:43:18 am »
Thanks again, y'all. Started on first try!
Reply #6October 23, 2021, 09:35:29 pm
« Reply #6 on: October 23, 2021, 09:35:29 pm »
Nice!
Reply #7January 17, 2022, 11:01:37 am
Chuck1978
  • 77
« Reply #7 on: January 17, 2022, 11:01:37 am »
Are you running the Land Rover pump's sprocket hub? Or the ALH sprocket's hub?
The Land Rover hub has the wrong offset unless you chuck it up in a lathe & machine a good bit of metal off of it. And maybe take a little off the ALH sprocket as well.
